daveoman1966 3,884 #26 Posted June 18, 2015 The belt should be on the INNER pulley...as in your pic, so that much is correct. 1)There are two spacers in the mule drive...one is a bit wider than the other. One is between the 2 pulleys and the other is between the outer pulley and the metal shield....put the wider shim there.2) Are you sure you have the deck and the mule drive mounted correctly. In your 2nd pic, I should NOT be able to see the bottom of the BLUE belt below the frame, but I can. That is to say, the bottom leg of the belt should be routed back toward the center of the tractor....not to the right side like in your pic. Something is definitely wrong there. It seems that your deck is mounted too far to the right, or you have an incompatible deck.Here are pics of how the belt should be routed, and the approximate angle you can see as it goes back under the tractor, to the middle of the deck. (Both are 42 side decks in my pics on a C-0120 and a 314-8) Share this post Link to post Share on other sites
daveoman1966 3,884 #27 Posted June 18, 2015 Maybe should be...but the belt came down to the pulley straighter when it was on the inside.little bit of the blue wore off but the belt stayed in tact for an hour of mowing....then I started getting some rattling from the deck. I'm thinking a spindle is giving up on me. It started getting louder quickly as it ran, so I shut her down again till I get it figured out, I'll post some pics..o and congrats on Steve from Vermont on his first purchase of a wheel horse, I told him to sign up on here so maybe we will see him soon. He purchased my D160 tonight! If a spindle is going bad, I have complete replacements or parts for them...most any spindle..and the pulleys too. contact me thru direct email....just clik this link:daveoman@windstream.net Share this post Link to post Share on other sites
psalms83:18 174 #28 Posted June 18, 2015 This might help make a good guess....i noticed the bolt that holds the blade on was loose by 1\2 inch so I tightened it....but when I ran it it still shook hard. None of the blade spindles seem to be wobbling but check out the video of the idler pulleyhmmmm. Seems a 8sec clip is bigger than 3mb Share this post Link to post Share on other sites
psalms83:18 174 #29 Posted June 18, 2015 and a 5 sec clip is too big.....and I can't adjust video resolution....from my phone Share this post Link to post Share on other sites
bmsgaffer 2,071 #30 Posted June 19, 2015 If you had a blade nut that loose there is a good chance that it wore the spindle shaft and/or the hole in the blade pretty badly so when you tightened it up you probably did not tighten it up centered.I would pull the blades off, look for wear and replace appropriately. Share this post Link to post Share on other sites
psalms83:18 174 #31 Posted June 24, 2015 (edited) Thanks gaffer...I did pull off the deck and found the front pulley to be making all the noise, but if I'm digging into it im not going to put old crap back on. I'm just gonna buy all new spindles. I am havi difficulty with numbers here.my deck is 36" wide by measurementthe numbers on the tag I can't find the exact # in the manualand what I did find seems to be for a 40somethin side discharge but mines a rear discharge.heres pics of what I see. Edited June 24, 2015 by psalms83:18 Clarification Share this post Link to post Share on other sites
psalms83:18 174 #32 Posted June 24, 2015 But I don't need to replace the pulleys right?? Where can I find all new spindles?? And maybe pulleys??i also like some other guys on here have those double blades Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #33 Posted June 24, 2015 The 75-48XS01 is a 1977 48" deck for a D-Series Automatic.7=19775=mower48=width of cutXS=side discharge01=parts list identifierIs the 36" rear discharge deck on the C-175?1980-1982 model 05-36MR011983-1984 model 05-36MR02I could also be an older or newer model.This file helps you identify mower spindle assemblies and tracks the changes made to the assemblies over the years.http://www.wheelhorseforum.com/files/file/671-chart-spindle-id-mower-rotary-1969-1989-35-pagespdf/Click on a mower in the index and it will take you to a single page showing all the spindles used and available for that model of deck.Garry 1 Share this post Link to post Share on other sites
bmsgaffer 2,071 #34 Posted June 24, 2015 Post a wanted ad for your spindles. I've bought a whole set of rebuilt spindles and pulleys on here, but you might save a good bit of cash if you tear into them and find out what NEEDs replacing. If the castings are good then you can buy the innerds. Share this post Link to post Share on other sites
daveoman1966 3,884 #35 Posted June 24, 2015 (edited) The cast iron center pulley for that model 48" mower deck is # 6756 and the new part # is 106848.I HAVE THAT PULLEY....NEW. It is listed on Ebay. I also have other parts for that deck....for further details, contact me here:daveoman@windstream.net(just clik that link) Edited June 24, 2015 by daveoman1966 Share this post Link to post Share on other sites
psalms83:18 174 #36 Posted June 24, 2015 Yeah but guys that must of been the wrong tag/serial that someone put on that deck.. Look at the measurements only 36" not 48 and its definitely not a D model deck.... Share this post Link to post Share on other sites
psalms83:18 174 #37 Posted June 24, 2015 I mud have accidentally mixed up which tag that pic went to, they were both stored together....but I can still now find any serial tag for the C modelIs the 36" rear discharge deck on theC-175?1980-1982 model 05-36MR011983-1984 model 05-36MR02Were you saying those are the serial numbers for a C model Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #38 Posted June 24, 2015 (edited) Is the 36" rear discharge deck on theC-175?1980-1982 model 05-36MR011983-1984 model 05-36MR02Were you saying those are the serial numbers for a C model Those are the model of decks sold those years for the C-Series but there are many more that would fit. The decks for the C-Series from 1973 to 1984 will all fit as will the 300-Series decks sold 1985 right up to this year because they made more of them even though they have not built any more tractors in the last 3 years.Garry Edited June 24, 2015 by gwest_ca Share this post Link to post Share on other sites
