Fordiesel69 272 #1 Posted June 2, 2015 Finally scored one one of these after years of looking. What are the differences between these? What is so much better about the 13? Share this post Link to post Share on other sites
squonk 46,562 #2 Posted June 2, 2015 I believe the block has a bit more meat in it for boring and other mods. Share this post Link to post Share on other sites
Fordiesel69 272 #3 Posted June 2, 2015 So from a stock standpoint, one will not be more powerful / cool better? Only if modding?This one runs too nice to even crack it open. Share this post Link to post Share on other sites
pacer 3,180 #4 Posted June 2, 2015 So, is this 12/13 fin thing on the block? Doesnt seem y'all are talking about the head? Was this a year related thing, like an older year was one way - 12 fin - and later yrs were 13?I've got a "official" replacement Kohler 16 in my D-160 and I do like that engine!Then a couple weeks ago I scored a gloat worthy complete K341down to the wiring still attached for $100. Yesterday I got it running (no spark - apparently condenser) and danged if that thing dont sound GOOD. I'll have to look into this fin thing. Share this post Link to post Share on other sites
groundhog47 448 #5 Posted June 2, 2015 Here's an excerpt from one of the engine builder guys: The 12 and 13 fin 16hp Kohler blocks - The 12 fin Kohler K-series and Magnum engine block models K341/M16 (16hp) have an indentation in the cooling fins (clearance for a straight oil fill/dipstick tube) and a threaded hole towards the bottom of the cylinder. This block have a thinner cylinder wall than the 13 fin block. This block is most common, and used mainly for light duty lawn and garden equipment applications, and can be safely bored up to a 3.825" [pulling] piston without danger of seriously weakening the integrity of the cylinder wall. But the 13 fin Kohler engine block model K341 (16hp) have a thicker cylinder wall. This block is somewhat rare, and used mainly for heavy duty industrial applications and can be bored for a much bigger [pulling] piston, up to 4-1/8". Both blocks originally have a STD cylinder bore of 3.750 6 Share this post Link to post Share on other sites
Fordiesel69 272 #6 Posted June 2, 2015 I guess I should just be happy I have a good runner and not worry about the fins then. I now own every size from 8HP to 16HP. Did I ever mention that these kohlers are my favorite? 1 Share this post Link to post Share on other sites
roadapples 6,987 #7 Posted June 2, 2015 some good info. here, thanks groundhog. I have one each of the 16`s and a 13 fin K321? the plot thickens! 1 Share this post Link to post Share on other sites
Saltyrob 0 #8 Posted April 1 Hello, I have a C160 with a Kohler K341 that I need to replace. My question is about the 4 mount bolts to secure the block to the frame. There are 12 hp and 14 hp K series engine out here. Will they have the same mount boat pattern as the K341? Thank you, Salty Share this post Link to post Share on other sites
sqrlgtr 2,926 #9 Posted April 1 Here is a pic of the k341 on my C-160 it has the boss but no threaded hole and as you can see has 13 fins. So I assume itis the thicker walled block? Share this post Link to post Share on other sites
rjg854 13,044 #10 Posted April 1 @Saltyrob I believe all big block oil pans are the same. 2 Share this post Link to post Share on other sites
squonk 46,562 #11 Posted April 1 8 hours ago, Saltyrob said: Hello, I have a C160 with a Kohler K341 that I need to replace. My question is about the 4 mount bolts to secure the block to the frame. There are 12 hp and 14 hp K series engine out here. Will they have the same mount boat pattern as the K341? Thank you, Salty As long as you don't get either one from another brand or a WH shaker plate engine they would be the same 2 Share this post Link to post Share on other sites
ineedanother 2,347 #12 Posted April 1 9 hours ago, sqrlgtr said: Here is a pic of the k341 on my C-160 it has the boss but no threaded hole and as you can see has 13 fins. So I assume itis the thicker walled block? My '76 c160 is the same but my c165 is not. I have to look at my '73 16 Auto tomorrow to see about that one. 1 Share this post Link to post Share on other sites
sqrlgtr 2,926 #13 Posted April 2 2 hours ago, ineedanother said: My '76 c160 is the same but my c165 is not. I have to look at my '73 16 Auto tomorrow to see about that one. I should have added mine is also a 76. Share this post Link to post Share on other sites
953 nut 66,085 #14 Posted April 2 On 4/1/2026 at 7:53 AM, Saltyrob said: Hello, I have a C160 with a Kohler K341 that I need to replace. My question is about the 4 mount bolts to secure the block to the frame. There are 12 hp and 14 hp K series engine out here. Will they have the same mount boat pattern as the K341? Thank you, Salty Be sure the oil pan type is the same, there are two distinctly different Kohler engine blocks out there. Share this post Link to post Share on other sites
ineedanother 2,347 #15 Posted April 2 20 hours ago, sqrlgtr said: I should have added mine is also a 76. I checked my '73 16 Auto today and it's also got 13 fins. Not sure what that means but here is the spec. #. Curious if the above post about that applies to all k341. Share this post Link to post Share on other sites
John c 156 #16 Posted April 4 I have a K241 with 13 fins, is that the same differences as on the 341, heavier cylinder walls ? Share this post Link to post Share on other sites
