MaineDad 87 #1 Posted June 1, 2015 Tomorrow Darren and I are going to upgrade my 1977 C-120 with the Ark Loader to the gear reduction / forward swept axle setup;Any insight or tips before we start? Any custom work needed? Its a dedicated loader tractor so the bellcrank and lift arm have been removed. Thanks in advance and of course I will post some pictures. Share this post Link to post Share on other sites
MaineDad 87 #2 Posted June 1, 2015 Here's what is being installed; Share this post Link to post Share on other sites
c-series don 10,575 #3 Posted June 1, 2015 Only thing I can say is I wish I had that set up for my C-141 with loader. After years of use my steering now skips. One of these days I will get that set up,good luck with yours. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #4 Posted June 1, 2015 You will need to drill 2 more holes in the frame for the steering block. Good luck! Share this post Link to post Share on other sites
MalMac 1,333 #5 Posted June 2, 2015 You will probably need to grind a little off the lifting bell crank. If I remember right about a 1/8". The crank just touches the back of the bevel gear. I just got done with my second conversion because my C141 was getting wore out with a Ark on it. Put the steering reduction on a 414-8 that the loader is going on. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #6 Posted June 2, 2015 You will probably need to grind a little off the lifting bell crank. If I remember right about a 1/8". The crank just touches the back of the bevel gear. I just got done with my second conversion because my C141 was getting wore out with a Ark on it. Put the steering reduction on a 414-8 that the loader is going on. It was so long ago I did mine I forgot about that. Get the grinder out.... Share this post Link to post Share on other sites
bmsgaffer 2,054 #7 Posted June 2, 2015 (edited) You will probably need to grind a little off the lifting bell crank. If I remember right about a 1/8". The crank just touches the back of the bevel gear. I just got done with my second conversion because my C141 was getting wore out with a Ark on it. Put the steering reduction on a 414-8 that the loader is going on. It was so long ago I did mine I forgot about that. Get the grinder out.... He said its a dedicated loader, so he removed the bell crank... Edited June 2, 2015 by bmsgaffer Share this post Link to post Share on other sites
MaineDad 87 #8 Posted June 3, 2015 Ok. Update. As instructed I had to drill the extra two holes. No problem except that the battery tray no longer fits between the engine and the steering block with this new set up. So, I am going to upgrade to an automotive battery and put it in the weight box in some type of marine box with a cover. Will take pictures tomorrow. Share this post Link to post Share on other sites
MaineDad 87 #9 Posted June 3, 2015 Yeah no bell crank Share this post Link to post Share on other sites
MalMac 1,333 #10 Posted June 3, 2015 Yeah, I really goofed that one up. Duh, but if you did have a bell crank you got to grind it. Lol. Share this post Link to post Share on other sites
wh5208speed 667 #11 Posted June 3, 2015 You will probably need to grind a little off the lifting bell crank. If I remember right about a 1/8". The crank just touches the back of the bevel gear. I just got done with my second conversion because my C141 was getting wore out with a Ark on it. Put the steering reduction on a 414-8 that the loader is going on. If you have access to the 520H parts tractor that you got your gear reduction steering from, you can use it's bell crank and it will clear without modification.Thad Share this post Link to post Share on other sites
MaineDad 87 #12 Posted June 4, 2015 So as mentioned above, if you do this upgrade on a 1977 C series, you will not have room for the battery and tray that was originally bolted right to the frame between the steering block and engine. So what I chose to do was to cut off the bolts on the battery tray and drill two new holes that match up with the bolts for the lift cable tube on top of the transmission;As you can see there is plenty of room under the seat. I went to Napa and bought two 2 gauge (red and black) 42" battery cables for $9 each. Installed everything back together and fired right up. I'll take better pictures later if the dang sun actually comes out. Share this post Link to post Share on other sites
