scotty 252 #1 Posted May 25, 2015 My 1989 414-8 i just bought will only start with a shot of gas in the air cleaner. But runs great and starts great for the rest of the day after. What would cause this? Share this post Link to post Share on other sites
skrusins 128 #2 Posted May 25, 2015 Fuel going back to the tank. When you give a shot of gas it is like priming it. Sometimes if you shut the gas valve offat the tank it keeps the gas in the line. Just open valve the next time you use it and see if that works. Share this post Link to post Share on other sites
boovuc 1,090 #3 Posted May 25, 2015 Scotty,Don't be surprised if shutting the fuel off at the tank doesn't work. If that valve leaks a little, it will still drain back and cause your starting problem. If your valve works well, it will fix it. Mine leaks slowly on the C-175 so I installed an "upper" inline shut off and that solved the problems. If you don't run them much, this happens and it also leaves behind deposits so it's best to keep the carb/fuel pump/lines wet and especially if they are not used much! Share this post Link to post Share on other sites
Rob R 977 #4 Posted May 25, 2015 Fixed mine with an in-line check valve.http://www.ebay.com/itm/221021780029?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT 1 Share this post Link to post Share on other sites
scotty 252 #5 Posted May 25, 2015 Ill try the in tank one first if not ill probably add an inline shut off. Share this post Link to post Share on other sites
pfrederi 18,917 #6 Posted May 25, 2015 Electric fuel pump!!! Solved the long..painfully long cranking required to start my 418A after it sat for a week or two. Share this post Link to post Share on other sites
BESTDOGEVER 218 #7 Posted May 25, 2015 Sometimes the fuel pump gets a little dried out and needs help getting primed a little trick I picked up is to take an old fashioned squirt type oil can and shoot a little bit of oil in the fuel pump from the out port it rehydrates the diaphragm and works for a fairly long time. Share this post Link to post Share on other sites
can whlvr 994 #8 Posted May 28, 2015 some guys have put primer bulbs on the fuel line,like on outboard boat motors Share this post Link to post Share on other sites
scotty 252 #9 Posted May 28, 2015 (edited) Hey thats a good idea anyone know where i could buy one cheap?? Edited May 28, 2015 by scotty Share this post Link to post Share on other sites
KATO 115 #10 Posted May 28, 2015 They also were used on snowmobiles so any marina or place that sells recreational /power sport vehicle parts should have them Share this post Link to post Share on other sites
skrusins 128 #11 Posted May 29, 2015 Hey thats a good idea anyone know where i could buy one cheap?? I've seen them on E-bay Share this post Link to post Share on other sites
