doc724 925 #1 Posted May 23, 2015 I have a 416H that is plagued by the typical fuse block and Molex connector problems. I have searched the forums for suppliers (other than Toro) for the the fuse block and the terminals with no luck. Toro will only sell the fuse block anyway. Bob Maynard has kits for the 9 pin Molex connector I am told.Anyway, I have surfed around and I believe that the fuse blocks and terminals are made by Delphi. They are a Delphi Pack-Con 3 product. They are available at Waytek Inc (on line) for reasonable price (I have not yet checked shipping costs).Delphi P/N's are as followsFuse block: 12004943 $1.45 ea Min qty=4Terminal 12GA: 12020400 (unplated brass) $.29 ea Min qty=50Terminal 14-16GA: 12020321 (unplated brass) $.14 each min qty=50Minimum qty make this a bit pricy and it is the terminals that fail, not the fuse block. Also, I believe there are tin plated terminals available and these are the ones to get. The tin plate will make a gas (not to be confused with gasoline) tight seal with the fuse so oxidation will be minimized.Anyone else found a source for these parts? Share this post Link to post Share on other sites
rmaynard 16,384 #2 Posted May 23, 2015 Can any of these be of help? These are the terminals that go into the relay blocks.Click on link and scroll to the bottom.http://www.rmaynard.com/electrical_parts.html Share this post Link to post Share on other sites
boovuc 1,090 #3 Posted May 24, 2015 One of our members here offers some specific parts for Onan Powered Wheelhorse tractors. His website specializes in retro kitchens but if you look, you'll find fuse block repair kits for the blocks in the WH's.http://classickitchensandmore.com/wheel-horse-tractors-parts-c-42/?zenid=kjrevi19bh591vgigu8jtcm945 1 Share this post Link to post Share on other sites
rick 257 #4 Posted June 7, 2015 Check out Del City, that is where I got my fuse terminals and block Share this post Link to post Share on other sites
doc724 925 #5 Posted June 7, 2015 Thx Rick. I ordered mine from Del City as well. Everything has now arrived-just need to set aside a few hours to work on it. Share this post Link to post Share on other sites
shallowwatersailor 3,214 #6 Posted June 7, 2015 (edited) I have also found them on eBay last year. The 5xi series uses the same block as well Edited June 7, 2015 by shallowwatersailor Share this post Link to post Share on other sites
rick 257 #7 Posted June 13, 2015 glad to be of help! Share this post Link to post Share on other sites
