857 horse 2,588 #1 Posted May 19, 2015 i have 2 857's both decks need maybe bearings,, I was wundering is it done and are parts avaliable??i would like to mow with one.....and i am willing to rebuild both decks Share this post Link to post Share on other sites
squonk 45,064 #2 Posted May 19, 2015 (edited) Yes. Gets lots of rags. The cross shaft bearings are common I Forget the numbers at the moment.I have some decent used bearings and gears that I plan on bringing to the show to sell. The most common thing I have found on the ones I have done is the cross bearings go bad and the cross shaft loosens in the brgs. It's supposed to be a press fit. The shaft itself gets worn down where the brg. rides and the shaft will chuck back and forth banging the gears Edited May 19, 2015 by squonk Share this post Link to post Share on other sites
857 horse 2,588 #3 Posted May 19, 2015 MR MIKE,,,,,,,,,,,,,,,,,I WILL BE AT THE SHOW,,,,,,,TENTED UP BESIDE THE WALFISH GANG.....I WILL LOOK FOR YEAH......I WILL TEAR THE NICE ONE APART BRING THE GOOD,,BADD AND BROKEN,,,,IF YOUR IN A COVERED BARN....I KNOW WHERE BILL JENKINS SETS UP.....TALK SOON.......HOWARD IN VA Share this post Link to post Share on other sites
boovuc 1,090 #4 Posted May 20, 2015 I would like to see someone post a "how to" on the gear-drive decks. I have two that need fixing! 1 Share this post Link to post Share on other sites
squonk 45,064 #5 Posted May 20, 2015 I remember changing the belts when I was like 12. What a job for a kid! The last deck I did I had a cross shaft custom made. They were still available a few years ago but $$$$$. I will look up the bearing numbers, I got them from Napa. I have a few sets of gears, a few decent bearings and I think a few bearing stands. Another common thing I have seen are the threads pulling out of the aluminum stands. I think a few people have tried to tighten the stand bolts with the belt tight putting a load on the threads and the spindle brgs go bad and the spindles cause the gears to bang some too Also the spindle housing cast iron cracks. I hope to set up across from John in the infield. 1 Share this post Link to post Share on other sites
