WH854 45 #1 Posted November 7, 2008 Mount block front is fastened to frame with 2 bolts. mount block rear is fastened to frame with set screws 3/8x16-1 3/4 and a nut.What is the reason for this can anybody tell me? I need one of those set screws, they are no longer available from Toro. model # 01-10K802 is the tractor Model! Any help will be appreciated! Chas Share this post Link to post Share on other sites
mcwh1950 2 #2 Posted November 7, 2008 you can buy one at the any hard ware store.... Share this post Link to post Share on other sites
WH854 45 #3 Posted November 13, 2008 I used a 1 inch cap screw. Hardware stores are as scarce as hens teeth in this area. I still don't know why a set screw was used! Chas :D Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,602 #4 Posted November 14, 2008 I strongly doubt if those were set screws.... :hide: Share this post Link to post Share on other sites
WH854 45 #5 Posted November 14, 2008 Well according to toro the rear mounting block is held to the frame with set screw p/n 909885and nut p/n 915113 set srw is 3/8X16-1 1/4 the set screw is NLA The reason I know this, the nut was broken off and i used a allen wrench to take it out of the mounting block. Chas Share this post Link to post Share on other sites
