parsonsponyz 385 #1 Posted May 12, 2015 I started to rewire my 416-8 and the only thing needed now is the plugs on the wiring harness for the relays. The local toro dealer said these were no longer available and I've tried a couple other places with no results. Does anybody know where I can get these plastic ends so the 416 can be revived? Share this post Link to post Share on other sites
WH nut 553 #2 Posted May 12, 2015 You can get individual 4 or 5 pin plugs at any parts store Share this post Link to post Share on other sites
rmaynard 17,495 #3 Posted May 12, 2015 ...the only thing needed now is the plugs on the wiring harness for the relays. Can you be a little more specific about what you need? Maybe a picture or reference a diagram in the parts list? Share this post Link to post Share on other sites
squonk 47,784 #4 Posted May 12, 2015 If it's the same as the common 5 blade auto relay you can get them at any auto parts store or if you need a gross of them , any pull your own part scrapyard Share this post Link to post Share on other sites
parsonsponyz 385 #5 Posted May 13, 2015 I haven't been able to stop at the parts store yet, thanks for all the ideas. Bob, I attached a picture of the plug on the wiring harness where the relay plugs in, it bolts to the plate behind the motor. Share this post Link to post Share on other sites
Save Old Iron 1,573 #7 Posted May 13, 2015 one source http://terminalsupplyco.com/Store/Product.aspx?pc=334+485+008 just google BOSCH RELAY for more sources Share this post Link to post Share on other sites
