decksetter 50 #1 Posted May 11, 2015 I can't be the only one that's done it. Anybody come up with a good solution for the tires hitting the back side of the deck in off camber situations? Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted May 12, 2015 I don't think there is much of a solution for you. I know that my 48" SD deck would hit my 26/12/12 rears let alone the 60" deck. Share this post Link to post Share on other sites
decksetter 50 #3 Posted May 12, 2015 I don't think there is much of a solution for you. I know that my 48" SD deck would hit my 26/12/12 rears let alone the 60" deck. Well that's unfortunate. I was hoping the 48 would at least clear. I got my tires used and the wheels are extra wide, so they only hit once in a while. They're dang close all the time though. Share this post Link to post Share on other sites
Pullstart 68,928 #4 Posted May 12, 2015 pictures of the interference? maybe if it's just at the edge of the tire you could get a racer's tire groover or use the old heat gun and chisel to shave a bit of rubber off that interference area.. Share this post Link to post Share on other sites
decksetter 50 #5 Posted May 12, 2015 Tires were used when I got them and had been cut for pulling, so I think a new set would rub really bad. These clear when just sitting but when driving and the deck shifts around they rub. Share this post Link to post Share on other sites
