Njdusty 0 #1 Posted May 7, 2015 Does anyone know of a replacement pump for the Cessna pump on the Ark loader? I have A 314-8 tractor. thanks, **** Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted May 8, 2015 Go to Northern Tool and look at their pumps. The Cessna Pump had a maximum pressure of 1000 PSI. Operating pressures on the Ark's were between 800 to 900 PSI. (Recommended). The Cessna would turn 2 to 4 GPM at a mx RPM of 4k. (WH turns at 3600 RPM). so use these numbers in your search. Surplus center also handles a lot of pumps and pulleys since you'll probably need to replace it as well. Before searching, measure the shaft length and diameter and the key width also. There are many expensive and as many cheap solutions between these two suppliers. Finding an exact replacement that will use your original brackets will be very hard to accomplish! 1 Share this post Link to post Share on other sites
Njdusty 0 #3 Posted May 8, 2015 Thank you for the info. I will start looking and let you know how I make out. Share this post Link to post Share on other sites
