W/H JUNKY 43 #1 Posted May 4, 2015 Hi all where would be a good place to get the idle pulleys for the drive belt and the mower belt for my commando 8. Partstree do not show them. Or is there another year that would have the same size. Thanks Chris. Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted May 4, 2015 The commando 8 probably has a 36" deck on it but it MAY be a 32" deck....either one was available. You need to look up parts for the DECK MODEL number...not the tractor model. So, do you have a 32 or 36" deck...side or rear discharge? ? ? Share this post Link to post Share on other sites
steve k 82 #3 Posted May 6, 2015 I pressed mine out then took them to napa and they matched them up with new ones. Share this post Link to post Share on other sites
W/H JUNKY 43 #4 Posted May 6, 2015 These are not on the deck this is on the right side of the tractor just behind the pedal that engage The mower deck and the same size for the drive belt tensioner Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #5 Posted May 6, 2015 Theses are likely the same pages for both mowers 36" deck 32" deck The 6593 bearing may be a 1615-2RS Described as 7/16"IDx1-1/8"ODx3/8" wide in service bulletin #393 Garry Share this post Link to post Share on other sites
305 380 #6 Posted May 6, 2015 i think the idler pulley you want is part # 92-7102 3" OD for a 1/2" wide belt and a 3/8" hole in the center bearing Share this post Link to post Share on other sites
W/H JUNKY 43 #7 Posted May 6, 2015 Yes sir that is the one thank you very much. Such a big help thanks again. Share this post Link to post Share on other sites
daveoman1966 3,882 #8 Posted May 6, 2015 pm sent... I have 3 of these... One is still on the rocker arm. Share this post Link to post Share on other sites
