byob73 0 #1 Posted May 2, 2015 When I lower the deck the deck wheels dont touch the ground it sits on the inside wheels (anti scalping ) rollers but still scalps the ground even with the height adjusted at the highest setting. I had to adjust the dial adjuster on the lift handle to keep it from scalping but it doesn't cut very even because it isn't sitting on the wheels its just floating around. Any suggestions? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #2 Posted May 2, 2015 I have WH decks but have never used one. Here is an operator manual and a poor parts list Not necessarily the deck you have but installation is the same. The only service bulletin I see that may influence what you are having problems with Garry Share this post Link to post Share on other sites
