dgjks6 8 #1 Posted November 5, 2008 Hope this is not been asked a zillion times, but I just got a plow and instead of storing the tractor this winter I am going to plow. I use regular 30W oil. Do I need to switch for the winter oil change. I am going to go with synthetic - but should I use a 10w30 or a 5w30? Greg Share this post Link to post Share on other sites
bambooheels 0 #2 Posted November 5, 2008 i wouldnt use a synthetic, just my opinion. BUT BOY OL BOY WILL THIS QUESTION STIR UP SOME FUN ON HERE.. :hide: Share this post Link to post Share on other sites
bluetuna08 0 #3 Posted November 5, 2008 ok...5w-30 is your best bet. I do not use a full synthetic due to my newest tractor being 14 years old. seals and gaskets get conditioned using fossil oil (dyno oil). when you switch to a full synthetic it want to recondition your old seals and typically this is a bad thing in old tractors. with that said I use castrol GTX synthetic blend 5w-30 all year around in all of my tractors...even my 1970 electro 12 and I have zero leaks. you have a better viscosity index with the GTX syn winter blend for better all around performance and lubrication. most engine manufacturers tell people not to switch to a synthetic oil until they have 20,000 miles on an automobile engine (duramax diesel). I actually switched at 22,000 miles in my truck. so I guess my recomendation as a certified lubrication specialist would be to go with the syn blend 5w-30. Share this post Link to post Share on other sites
HorseFixer 2,013 #4 Posted November 5, 2008 :hide: dgjks6 the truth is out there! matter of fact right in front of you? :D Share this post Link to post Share on other sites
Butch 194 #5 Posted November 5, 2008 Yep, oil sure can raise some interesting opinions and points. Then it depends if the engine is splash lubed or oil pump lubed. I like synthetics myself. Butch Share this post Link to post Share on other sites
canam1991 2 #6 Posted November 5, 2008 this is how you rate the best oil 1.valvoline 2.mobil1. 3 castrol GTX 4. quaker state 5. pennzoil yuck lol i would use 5w-30 for winter Share this post Link to post Share on other sites
