bakes 0 #1 Posted April 26, 2015 Hello forum members, I am the proud new owner of a 520H, with 318 hrs..This machine unfortuanatly, has not seen the inside of a building in some time. It will now with me as long as I own it. I need to find new deck pulleys, originals are badly pitted on the inside, where the belt contacts pulleys, chewing up the belt. Does anyone know where I can find a part number for a replacement?? Serial numbers are faded on deck and tractor. This is a 48" side discharge deck, pulleys are non keyed, appear to be about 5 1/4 in diameter with a 5/8" diameter center hole. Any help would be appreciated. Share this post Link to post Share on other sites
953 nut 64,279 #2 Posted April 26, 2015 Parts tree on line or a Toro dealer should be able to fill your needs. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted April 26, 2015 You may have this deck or a recycler deck When you see the price of replacement pulleys you may want to remove the belts and use a flat file to smooth out the rust. You can get parts prices here. If it is priced the part should be available from any Toro dealer. http://www.partstree.com/parts/ Garry Share this post Link to post Share on other sites
can whlvr 994 #4 Posted April 26, 2015 or contact some of our local parts guye,ive bought deck pullies at a great discount and in good shape Share this post Link to post Share on other sites
