rexman72 210 #1 Posted April 23, 2015 I bought this blade to fab it up to a mid mount plow.I decided to try it on the rear hitch and move some dirt to see how it worked.I like the fact that I can swivwl the blade to push instead of pulling. 5 Share this post Link to post Share on other sites
953 nut 69,830 #2 Posted April 23, 2015 ​Nice attachment, do you have any idea what it was on originally? Share this post Link to post Share on other sites
rexman72 210 #3 Posted April 24, 2015 Not sure what it came off as it was was in a barn sitting there and was in rough shape.I went and took it apart and sand blasted it and primed and painted it.Alsoput new bolts etc on it.I hadbetter luck turning the blade around so I could see better and pushed the dirt instead of pulling it. Share this post Link to post Share on other sites
Rob R 989 #4 Posted April 24, 2015 I have one that looks almost identical that I converted to work on my GT 14 rear 3 PT hitch (with an adapted 2 inch trailer hitch), the blade was originally from a Sears Suburban. When the weather gets a bit brighter I will add some pics. Note be a bit careful when you use in reverse i.e. just do the final grading or you will probably bend or break something. 2 Share this post Link to post Share on other sites
