gixxer 0 #1 Posted April 21, 2015 I have a 520H, I installed a new battery the other day. The tractor starts and runs fine, but if I disconnect the battery while the tractor is running, the engine shuts right down. Is this normal ? I never noticed this before , no fuses are blown. I haven't checked voltage outputs yet. Just wanted to get an opinion first on what might be bad or if this is normal. Thank you Share this post Link to post Share on other sites
Save Old Iron 1,573 #2 Posted April 21, 2015 The 520 with an Onan will have an electronic ignition module firing the coil. Without the smoothing effects of the battery, pulsating DC output from the RR unit might not bother a points based engine but I strongly suspect it will not be well liked by an electronic ignition system. Share this post Link to post Share on other sites
WH nut 553 #3 Posted April 21, 2015 For one, never unhook the battery while running. Next check battery voltage while running before you decide there is a problem. 1 Share this post Link to post Share on other sites
rmaynard 16,698 #4 Posted April 21, 2015 Most 300/400/520's have a warning label right next to the battery. Hope you have not damaged anything. Share this post Link to post Share on other sites
gixxer 0 #5 Posted April 21, 2015 Thank you for the info....the battery was disconnected and it shut down instantly..no wires touched anything other then the battery terminal.....I always thought it would stay running without the battery as long as the wires never touched anything. Nothing seems wrong with it as of now....My tractor doesn't have a warning label near the battery.... Share this post Link to post Share on other sites
953 nut 63,045 #6 Posted April 21, 2015 As you have already discovered there are lots of great people here who will help you enjoy your . Share this post Link to post Share on other sites
WH nut 553 #7 Posted April 21, 2015 When you disconnect the battery it causes a spike in the electrical system and can damage to components Share this post Link to post Share on other sites
