Kenworth 0 #1 Posted April 17, 2015 Hello all first time poster here and new member from upstate NY. Just got a nice 520H, year 91-92 in great condition with 381 hrs... anyway I need some help. I read the owners/parts manual,& catalog,searched the net and for the life of me cannot find a part number or anything related to the deck blades (length/hole diameter). I need a new set of blades. The deck is a 48" SD. MODEL # 15-48sc03. Does anyone out there have a part#. I could only find "high lift" blades, but im looking for "low lift" or mulching blades. Share this post Link to post Share on other sites
Kenworth 0 #2 Posted April 17, 2015 EDIT: the site I found that had "high lift" blades did NOT give any details to length, and hole/bolt diameter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,918 #3 Posted April 17, 2015 The 106078 blade has been replaced by 106637 3-blade set at Toro. Napa 3 of # 7-04563 Oregon 3 of # 91-806 Oregon Gator Mulcher 3 of # 90-944 Oregon Gator Mulcher 3-in-1 3 of # 90-644 Garry Share this post Link to post Share on other sites
cleat 8,344 #4 Posted April 17, 2015 Good info. Thanks Share this post Link to post Share on other sites
bmsgaffer 2,065 #5 Posted April 17, 2015 Speaking from experience, unless the deck was designed for mulching blades (WH side discharge decks were not) stick with the high lift blades. I tried switching to oregon gators and the results were bad. First off, it didn't mulch that much so I still had to sweep when the grass was tall. Then the deck didn't have enough lift to stand the blades up and so when I went over the yard with my sweeper it looked like I cut the yard with a string trimmer. Your mileage may vary. Some guys on here will bolt a second blade 90* offset from the first (for a total of 6 blades) and have had good luck with that. I have not yet tried this method, so I cant comment on it myself. Share this post Link to post Share on other sites
Kenworth 0 #6 Posted April 18, 2015 Thank you GWest so much for the reply and answers. Also thank you bmsgaffer, i will consider that. Share this post Link to post Share on other sites
