Tom. 70 #1 Posted April 13, 2015 Hi all, With the recent sale of the Brinly plough for over £600 on that well-known auction site and having no luck finding one and after seeing Marks amazing adaptation of a Barford atom plough I set about adapting a spare Barford atom plough I had. I only have a slot hitch at the moment so I adapted it to suit a slot hitch but no welding or modification was made to the plough I just used the original bolt holes which means it can be reverted back to a plough for a Barford atom or even changed for a sleeve hitch. I cut a part out of some 8" box section we had to make the L-shaped bracket and then used a piece off of an old forklift carriage for the bar which will go in the slot hitch and be welded to the underside of the L-shaped bracket. It's currently only G-clamped. I will cut the bracket down so there is no risk of it hitting the fender and so the adjustment lever has enough space to move. Tom 2 Share this post Link to post Share on other sites
scotty 252 #2 Posted April 13, 2015 Out of curiosity do the front ags seem to work good? They look tough. Share this post Link to post Share on other sites
farmer 1,081 #3 Posted April 13, 2015 If you intend to use your plough, remember you have to mount it tilted to allow for the wheels in the furrow. If it is for display/show, then it's fine as is. I 1 Share this post Link to post Share on other sites
