boovuc
New Battery Time!
boovuc
Anyone here have experience with NAPA Lawn & Garden Batteries?
How about DieHard Batteries.
Going to buy two 300+ CCA batteries this year as my cycle times have my two biggest batteries ready to be switched out.
I do have a new Tractor Supply Store that opened close by also. Just don't want to buy another 1 and done. You know, like most collage basketball players at Kentucky!  :happy-jumpeveryone:
(That should get a response)!
Thanks Guys!
squonk
I have 4 360 CCA Batts from TSC with no issues.
tlb41
I got my last two batteries from carquest and they work great.
They are around 500 CCA and I can get you the exact numbers tomorrow if you would like?
Troy
scotty
I like interstate batteries.Mine is quite old and still going.
sorekiwi
I have 2 dead Napa batteries in my garage right now, both died after 2 years.
I am not sure that there is a decent L&G battery out there, 2 years is about as good as I get, but others tell me they get 4 or 5 years out them.
Racinbob
In the decades I've been buying L&G batteries I really haven't found one that stands out. I've used Diehards, Interstates, Walmart whatevers, Duralast, and who knows what else. If I had to pick a favorite I would probably go with the Duralast but that's based more on their automotive batteries. Just a couple of weeks ago I replaced a Duralast that did manage almost 5 years and it was a measly 285 CCA but remember that I don't have to worry about cold weather starting. I went with another Duralast and because of sale pricing I went with 425 CCA this time. The biggest thing to stretch their lives is proper maintenance. Every spring I disconnect and clean the terminals even if they aren't showing any crud.
shallowwatersailor
Since using  Battery Tenders/Battery Minders on my batteries, it has increased their lifetime. I use to replace one or two a year. Since then, I haven't bought one in two years (knock on wood!  :handgestures-fingerscrossed: ) The tractors that aren't used have the batteries pulled to sit on the bench connected to the tender/minder over winter. They get wired in parallel. The tractors that remain active have permanent leads to the batteries for the tender/minder or solar panel..
The two brands that I use are Battery Minder and Battery Tender. Both seem to do the job. What I don't recommend is the one by HF. I tried one three years ago and the battery went dead.
Aldon
I bought a Battery Tender to try over winter. Pricey in comparison but also much smaller in size. Might be handy to have the extra room as I make changes.......
Edited by Aldon
boovuc
Thanks for the posts guys!
TLB..............We have a Carquest in Lock haven but I've never been down there to take a peek in. I'll check them out!
