tractorchick 399 #1 Posted April 9, 2015 I am going to attach the deck on this model, but am looking for a photo or manual to see how the deck attaches. Can anyone help? Thank you, Kate Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,733 #2 Posted April 9, 2015 1968 42" width of cut side discharge 1969 1970 1971 1972 If your deck is a different size let us know. Garry Share this post Link to post Share on other sites
tractorchick 399 #3 Posted April 9, 2015 I thank you very much. I am really bad about finding those manuals on here!!! I'm sure if it were a snake it would have bit me! lol! 1 Share this post Link to post Share on other sites
tractorchick 399 #4 Posted April 10, 2015 NOW I have another question. Apparently the key switch burnt up on this unit. I wonder how I can find the part number for that key switch so I can order another? Share this post Link to post Share on other sites
Sparky-(Admin) 23,766 #5 Posted April 10, 2015 I think the Raiders had two different ignitions over the years...do you know exactly what year yours is? Mike........... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,733 #6 Posted April 10, 2015 The spec number off the engine decal should identify the tractor model if that is unknown. Garry 1 Share this post Link to post Share on other sites
tractorchick 399 #7 Posted April 10, 2015 It is serial 570451, model 1-6241 and I looked that up and it shows that it is a 1969 Wheel Horse Raider Engine, K301-S 471447C Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,733 #8 Posted April 10, 2015 Kohler K301S-47147c uses breakerless magneto ignition and there was a change to the ignition switch way back. Should be a 4-position key switch part number 8362. This is a heavy duty switch that does not use a starter solenoid and likely only available from Toro. There may be a cheaper 3-position magneto ignition switch if you add a solenoid to carry the starter load. Here are 2 service bulletins on the switch you can download Garry Share this post Link to post Share on other sites
Irv 115 #9 Posted April 10, 2015 And be careful not to use the wrong switch or cross wires as you can easily burn up the coil and/or the "trigger switch" which are hard to find and exspensive. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,733 #10 Posted April 11, 2015 Can not find an original wiring diagram for the 1969 Raider 12 model 1-6241 but the 1970 model 1-6252 uses the same K301S-47147c engine so have to assume the tractor wiring is the same. That operator manual we do have and the wiring diagram is in it. Garry Share this post Link to post Share on other sites
tractorchick 399 #11 Posted April 13, 2015 Thank you -- very helpful! Share this post Link to post Share on other sites
Twohorses 2 #12 Posted August 1, 2015 Does anyone have a PDF of the manual for the 1-6241. I have two of these beauties and would like to have the manual for the 1969 raider 12. Share this post Link to post Share on other sites
