marvins 16 #1 Posted April 8, 2015 I can not get roll pin out of a 70s steering wheel any ideas. Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted April 8, 2015 Wedge a 2x4 tightly between the collar of the steering wheel and a tree. Punch the rollpin out toward the 2x4. 3 Share this post Link to post Share on other sites
Tankman 3,523 #3 Posted April 9, 2015 Wedge a 2x4 tightly between the collar of the steering wheel and a tree. Punch the rollpin out toward the 2x4. After the roll pin is out, the steering wheel might not be easy either. A real PITA for sure! 1 Share this post Link to post Share on other sites
MalMac 1,333 #4 Posted April 9, 2015 Make sure you soak it good for a couple of days with PB Blaster. Also use a Roll Pin Punch. you find it will stay on the pin a lot easier and will allow for a more solid blow from your hammer. 2 Share this post Link to post Share on other sites
rmaynard 16,504 #5 Posted April 9, 2015 If you do a search, you will find that this has been a much discussed problem with some very creative answers. What's the model number tractor we are talking about? 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #6 Posted April 9, 2015 I can't argue with any of the above comments. I have fought that battle before. Good luck and keep us posted. Glenn Share this post Link to post Share on other sites
daveoman1966 3,866 #7 Posted April 9, 2015 (edited) If you have access to a 20-ton shop press, wiggle the steering wheel shaft into it and apply pressure to the shaft. Be prepared for a loud BANG when the roll pin shears off. That roll pin is old, hard, rusty, and brittle...all of which contribute to the BANG you'll hear. I've done this successfully several times, without damaging the s/wheel. If you have to sacrifice the alum dash housing, they are available y here or on ebay. Edited April 9, 2015 by daveoman1966 Share this post Link to post Share on other sites
elliot ness 1,916 #8 Posted April 9, 2015 Soak it good with PB blast for several days. Then what ever you do will be easier! Share this post Link to post Share on other sites
marvins 16 #9 Posted April 9, 2015 it is a c160 tractor Share this post Link to post Share on other sites
