GT14 243 #26 Posted May 1, 2015 Getting back to work on the project. Went with solid mounts for now, offset is about 1.5 inch. the engine shaft has a step down which doesn't allow drive to be close to the engine case. Also added new rims and rubber 2 Share this post Link to post Share on other sites
Toasty 52 #27 Posted May 1, 2015 looking great so far. Share this post Link to post Share on other sites
Wheel-N-It 2,978 #28 Posted May 3, 2015 Yes, looking good. Curious how this is going to perform for you. Share this post Link to post Share on other sites
elliot ness 1,916 #30 Posted May 3, 2015 Very nice fab work .I like the idea of an electric clutch. :bow-blue: Share this post Link to post Share on other sites
GT14 243 #31 Posted May 6, 2015 The new Models are out! 9 Share this post Link to post Share on other sites
chex313 123 #32 Posted May 6, 2015 (edited) I would like to place my order! Need a couple covers for the Mufflers... Edited May 6, 2015 by chex313 Share this post Link to post Share on other sites
shallowwatersailor 3,222 #33 Posted May 7, 2015 The new Models are out! IMG_1483.JPG Are the Pepper Pots going to provide enough backpressure? I like the new decals! Share this post Link to post Share on other sites
Theroundhousernr 589 #34 Posted May 7, 2015 If the motor would have been at the proper height for the belt guard, I take it the motor wouldn't have fit? That thing must be a beast of a thing not to fit under a black hood! Share this post Link to post Share on other sites
Pullstart 71,571 #35 Posted May 7, 2015 yeah that'll sound good n mean! Share this post Link to post Share on other sites
GT14 243 #36 Posted May 18, 2015 All mechanical work is done, I am repairiing the plastic fender now.Have the key installed in dash and used original choke and throttle cables.New Headlights installed.Broken fender will be repaired with a piece of 1/8 ABS, sheet metal and JB Weld. 4 Share this post Link to post Share on other sites
bmsgaffer 2,071 #38 Posted May 26, 2015 Nice! Now put that fender up on a shelf so it doesn't break again! 2 Share this post Link to post Share on other sites
GT14 243 #39 Posted May 27, 2015 (edited) Nice! Now put that fender up on a shelf so it doesn't break again! Tractor would look odd without a seat pan. Would love to find a nice metal replacement, the plastic is not my style. Edited May 27, 2015 by GT14 1 Share this post Link to post Share on other sites
Catmanii 36 #40 Posted May 27, 2015 I have had to repair mine also, just a long crack. I used fiberglass on the inside and smoothed it back up and painted the pan. The plastic pans are a real pain to get gas in the tank since it's so far down to the cap. I also would like a metal pan, but so far stayed with the plastic since that's what come on it. 1 Share this post Link to post Share on other sites
bowtieguy 334 #41 Posted May 28, 2015 (edited) I have a couple C-175's, both with blown engines, so I have been following your project....my local HF will not bring in an engine to their store...says I must order it on line.So, did you order on line and what was total cost?....did you have to pay for shipping>?500 bucks sounds like alot of money to put on an ole WH but compared to 2K for a new "throwaway mtd" it sounds like a "no brainer".....Does the engine have holes to mount a manual WH pto?Also my local HF told me that the HF store in Independence, MO has one on display (not for sale)...may have to make a trip and look at it!! Edited May 28, 2015 by bowtieguy 2 Share this post Link to post Share on other sites
GT14 243 #42 Posted May 28, 2015 I have a couple C-175's, both with blown engines, so I have been following your project....my local HF will not bring in an engine to their store...says I must order it on line.So, did you order on line and what was total cost?....did you have to pay for shipping>?500 bucks sounds like alot of money to put on an ole WH but compared to 2K for a new "throwaway mtd" it sounds like a "no brainer".....Does the engine have holes to mount a manual WH pto?Also my local HF told me that the HF store in Independence, MO has one on display (not for sale)...may have to make a trip and look at it!!--------------------------------------If you can still use coupon code (21741290) you can get it for 524$ Shipping is 6.95$Lots of tapped hole on the side to mount PTO (I am not using the manual type because of side trust on the crank bearing) Share this post Link to post Share on other sites
shallowwatersailor 3,222 #43 Posted May 28, 2015 See if your store has the 13,500 Peak/11,000 Running Watts generator. You could save yourself mileage as it uses the same engine. If you can hold out, I'm thinking that HF may run a 25% coupon for 7/4. 1 Share this post Link to post Share on other sites
GT14 243 #44 Posted May 28, 2015 See if your store has the 13,500 Peak/11,000 Running Watts generator. You could save yourself mileage as it uses the same engine. If you can hold out, I'm thinking that HF may run a 25% coupon for 7/4. Regular coupons exclude Predator engines. The code I mentioned is the only one that worked. If you call customer service they can tell you about promotions and what works. Share this post Link to post Share on other sites
shallowwatersailor 3,222 #45 Posted May 28, 2015 (edited) Good to know that coupon works. I know that is what the coupon normally says - but I have used a 25% coupon (it even said excluded Predator engines) to purchase a 13 hp engine online. Another forum member has also had success. I think the key is to do it online and have it shipped.It doesn't hurt to at least try. Edited May 28, 2015 by shallowwatersailor 1 Share this post Link to post Share on other sites
GT14 243 #46 Posted May 29, 2015 I have had to repair mine also, just a long crack. I used fiberglass on the inside and smoothed it back up and painted the pan. The plastic pans are a real pain to get gas in the tank since it's so far down to the cap. I also would like a metal pan, but so far stayed with the plastic since that's what come on it. Mine was a real mess, long crack down the middle (front and back), small cracks on both side and the big chug missing. I took about 8 hrs. to do all the repairs and paint. Share this post Link to post Share on other sites
Aldon 4,834 #47 Posted May 29, 2015 The coupon listed in this thread has evidently expired. A new 20% off coupon (any one item) is available June 1st. Probably in store will not allow use on engine but online it appeared to work. I may grab one and retrofit my C161 as I have a spare electric clutch handy. I have a foot control kit I have been holding onto as i wanted a more reliability. My Briggs is attention needy. This engine, clutch and foot controlled hydro should be just the ticket:-) 2 Share this post Link to post Share on other sites
bowtieguy 334 #48 Posted May 31, 2015 Made a trip to the Independence MO store...they have one on display....AND ONE IN STOCK for sale...now to wait for the right coupon!!! 2 Share this post Link to post Share on other sites
GT14 243 #49 Posted June 3, 2015 Ok the big day has come, out for some pics. 13 Share this post Link to post Share on other sites
bmsgaffer 2,071 #50 Posted June 3, 2015 Cool! Can we get a start up and running video?That thing looks loud with the pepper pots on there! Share this post Link to post Share on other sites
