RT WH416H 10 #1 Posted April 3, 2015 I have a 520h and need the belt size and information for the tiller attachment. Im also looking for the numbers to other manufacturers as options. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,848 #2 Posted April 3, 2015 1988-89 tiller 07-36TL03 1990-91 tiller 07-36TL04 1992 tiller 07-36TL05 1993-2003 tiller 79370 all list a 110265 belt which is HA x 141". That is 1/2" x 141" and needs to be a belt that is designed to run over a flat idle. This bends the belt backwards. Not aware of anyone able to supply other than Toro. Even Gates does not have a replacement. Garry Adding - Below Navig8r posted that a Gates 6686 BR belt 1/2" x 141-3/8" works well and should be the proper design. Share this post Link to post Share on other sites
Navig8r 132 #4 Posted April 3, 2015 Not sure if this helps, but I have a '94 416-H and tiller... Last year, I got a Gates 6686 BR, it is shown as 1/2" x 141 3/8", and is a Lawn and Garden Belt. I ran it on my tiller no problem, even tilling some very hard, rocky ground. The OEM was pricey, aso I figured I'd give this one a shot first. So far, so good! Good Luck! Share this post Link to post Share on other sites
