252H 6 #1 Posted April 1, 2015 (edited) Hi all, i haven't been on here much so im not sure if this is the right section but my 252H steering went out and i need a new steering gear. Does anyone have a 252 or 257 parts tractor because i really need to fix my garden tractor. If not where can i get a steering gear? Thank you :-) Edited April 1, 2015 by 252H Share this post Link to post Share on other sites
JackC 617 #2 Posted April 1, 2015 Search eBay for "wheel horse" 252H. The seller may have the parts you need. Share this post Link to post Share on other sites
252H 6 #3 Posted April 1, 2015 Search eBay for "wheel horse" 252H. The seller may have the parts you need. I already tried to find the part on ebay, no luck Share this post Link to post Share on other sites
JackC 617 #4 Posted April 1, 2015 Which part do you need? Here is a parts diagram: http://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/22-13ke02-252-h-toro-252-h-tractor-1989/front-axle-and-steering-mower-hanger/ eBay auction 141323481504 is the steering shaft. If you ask the seller he may have the other parts. 1 Share this post Link to post Share on other sites
252H 6 #5 Posted April 1, 2015 (edited) I need the part the shaft connects to. Sort of shaped like a rooster tail with grooves its not available on part tree Edited April 1, 2015 by 252H Share this post Link to post Share on other sites
Don1977 605 #6 Posted April 1, 2015 (edited) On the garden tractors you can place shim washers behind the carter pin to tighten the steering. A new carter pin that just fits the hole will help to, as they get bent and worn. Haven't look at at one of those I guess they are the same. Unless it's really worn shimming usually fixes it. The upper steer column can also cause problems as the hole in the hood stand wares allowing the column to move around. The 300, 400, and 500 series garden tractors have the same problem. Edited April 1, 2015 by Don1977 Share this post Link to post Share on other sites
252H 6 #7 Posted April 1, 2015 My steer column moves around too. Its too broken to shim Share this post Link to post Share on other sites
