BairleaFarm
Leaf vac fan
BairleaFarm
whats the inside of a blower look like for a leaf vac? is it something like a squiell cage off a furnace? or a big version of a shop vac fan?
Sparky
I think its more like the second impeller on a 2 stage snowblower.
Mike...........
refracman
Dave
Most if not all are a four blade setup about 12 inches in diameter within a 15 encloser, blades a 4 inches wide. Most a driven with a 3/4 inch shaft motor.
BairleaFarm
Ive never seen a snow blower so that wont help either. :banghead: I still cant picture it in my head by your description. sorry.
Rollerman
David my PeCo brand vac has two cast aluminium paddles in the blower housing.
They conform to the shape of the inside of the housing & clamp together right over the output shaft on the engine.
Every company has a differant design.
A furnace type fan would not work.
It get pluged up fast & also to get things going fast enough to move the volume of air....you'd well...have a nice time bomb.
sorekiwi
In the other thread, I was suggesting using the furnace fan as a blower not a sucker (!!)
BairleaFarm
I know - Ive got one ill be using as a blower.
