ibskot 37 #1 Posted March 22, 2015 Anybody know the distance of travel for the clevis hitch....from the down position to the up position? I just moved the hitch system from one tractor to another and the travel seems minimal. The high isn't very high and the low isn't very low. Thank you for your help. Share this post Link to post Share on other sites
Don1977 605 #2 Posted March 22, 2015 Yes they don't lift very high. I think don't think low needs to be much more then level. Share this post Link to post Share on other sites
ibskot 37 #3 Posted March 22, 2015 I don't think up will clear the bumps in my yard on the way to the garden spot. I see videos of ones that go way up, but if I make it go way up, it won't come down enough. Share this post Link to post Share on other sites
Sparky-(Admin) 24,658 #4 Posted March 22, 2015 Not familiar with these hitches but I wonder if they are lifting the attachment by hand and chaining it up (higher) for transport, then unchaining and letting the lift mechanism take over while its being worked . Mike........ Share this post Link to post Share on other sites
wallfish 19,359 #5 Posted March 22, 2015 I'm not too familiar with it either but where the cable is connected to the bell crank would make a difference. Closer to the center pivot point will provide more power but less travel and the opposite the farther out towards the end it is attached. 1 Share this post Link to post Share on other sites
groundhog47 447 #6 Posted March 23, 2015 (edited) Somewhere I read in an OM where you would need to modify older hitch with a lower hole in lift arm, thanks to Garry who supplied the sheet showing holes attached drawing: Attached PDF is info where found modification, must be in manuals but can't relocare to thank original submitter. whclevishitchmod4lift.pdf Edited March 23, 2015 by groundhog47 1 Share this post Link to post Share on other sites
ibskot 37 #7 Posted March 23, 2015 Thanks....i will do this. Mine isn't a c series....however the hitch isn't from that tractor so who knows. will do that. Share this post Link to post Share on other sites
