randym 3 #1 Posted March 15, 2015 Just picked up a 1992 520-H to take advantage of the hydraulic lift when using my two-stage snow thrower. My son's helping me work out a few mechanical issues; in meantime, I'm puzzled about putting chains on the rear tires. I've always used Wheel Horse 50 lb. weights and chains on my 312-8 with no problem. But as you can see on the attached photo (hope it attaches) there is only about 1/4" clearance between the inside of my rear tires and the gas tank supports. No way chains will clear that. The wheels as currently mounted appear to be flush with the end of the axle. (Hope I've got my terminology right.) Is this normal? Do you think there might be some spacers missing that would hold the wheels out further? Also, while you're being helpful, anyone know if the wheel weights I used on my 312-8 (with smaller wheels) will fit the wheels on my 520-H? What about the bolts; will they be long enough? (Tires on 520-H are 23 x 10.5 x 12. Tires on 312-8 are 22 x 9 x 12). Son is suggesting I put the smaller wheels and tires from the 312-8 on the 520-H, and put the larger wheels and tires from the 520-H on the 312. That way, don't have to worry about buying new chains, and perhaps buying new weights. I will be using the 312 for mowing, the 520-H for snowblowing. Thanks. Share this post Link to post Share on other sites
rmaynard 16,588 #2 Posted March 15, 2015 Are your hubs flush with the ends of the axles? Share this post Link to post Share on other sites
randym 3 #3 Posted March 15, 2015 Yes, hubs are flush with axles. Share this post Link to post Share on other sites
rmaynard 16,588 #4 Posted March 15, 2015 By the way, 10.5" tires are a little fat if mounted on 7" rims. What size are your rims? Share this post Link to post Share on other sites
baerpath 517 #5 Posted March 15, 2015 (edited) Wheel Horse offered spacers to put the tire out farther. Any good auto parts place should have them or you can make your own. I would probably just switch tires and rims around for now Edited March 15, 2015 by baerpath Share this post Link to post Share on other sites
randym 3 #6 Posted March 15, 2015 I'm not sure what size rims are. I assumed these were factory stock all the way around. Tire size matches what owner's manual says. Unfortunately, bad back prevents me from taking off wheels myself right now and seeing any more detail; will have to wait till son's next visit! Share this post Link to post Share on other sites
squonk 44,615 #7 Posted March 15, 2015 Ford rim spacers at auto zone. You need to use longer wheel studs and nuts. http://www.autozone.com/tire-repair-and-tire-wheel/disc-brake-wheel-spacer/dorman-autograde-5-16-in-thick-4-1-2-5-1-2-in-bolt-circle-5-lug-wheel-spacer/972863_0_0/ Share this post Link to post Share on other sites
randym 3 #8 Posted March 15, 2015 Thanks, guys. Appreciate the advice. Share this post Link to post Share on other sites
ericj 1,579 #9 Posted March 15, 2015 somebody probably put the wrong wheels on your 520 with the wrong off set when you change the wheels over to the 312 look at the back space on both rims, if wrong tou should be able to measure the difference and be sure, even though the rims are different widths the back space should be the same. good luck eric j 1 Share this post Link to post Share on other sites
Eric C 109 #10 Posted March 15, 2015 (edited) Eric J beat me to it. I agree exactly. I swapped out 23x8.5 AG tires (on 7.5rims) that were on my 520 with 23x10.5 turfs (on 8.5 rims)that were from my Crapsman GT. The offset on the Sears rims didn't allow room for chains either. Iirc, the tire rubbed on the left side. To remedy this, I used 2" wheel spacers from xtreme motor works. Sent from my iPhone using Tapatalk Edited March 15, 2015 by Eric C Share this post Link to post Share on other sites
cleat 7,659 #12 Posted March 15, 2015 Are you sure the wheels are bolted on properly with the deep dish in. Also, tire valves should be on the inside. My 520's all have lots of space on the inside. Cleat Share this post Link to post Share on other sites
randym 3 #13 Posted March 15, 2015 Holy cow, cleat, you may be onto something. I'll have to look at that because, by gosh, the stems are on the outside. And come to think of it, the stems are on the inside for my 312-8 and my 312-A. And I also remarked to my son when we brought the tractor home that the distance between the front wheels (outside edge to outside edge) seemed a lot greater on the front of this tractor than the rear. Here's hoping it's something this simple. Thanks. Share this post Link to post Share on other sites
randym 3 #14 Posted March 15, 2015 Although I would note that chrome Wheel Horse hubcaps are on those wheels, and I wouldn't think the hubcaps would fit on the wrong side of the wheel, would they? Share this post Link to post Share on other sites
randym 3 #15 Posted March 15, 2015 Here's a photo of the wheel as mounted. It looks to be mounted proper direction to me; same as wheels on my other Wheel Horse tractors (312-8 and 312-A). Even though valve stem is facing out on this tire, unlike on my other tractors. Share this post Link to post Share on other sites
Eric C 109 #16 Posted March 15, 2015 They are definitely not WH wheels. The offset should be about 1 1/2 to 2 inches. Not sure. Here's a pic or 3 of my original wheels. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
rmaynard 16,588 #17 Posted March 15, 2015 I have 7-1/2" rims on my 416-H. From the back of the rim at the center hole to the edge of the rim at the tire is 2". I think you have the wrong rims. Without the proper width from the outside of one rear tire to the other, you have a very unstable tractor. Share this post Link to post Share on other sites
randym 3 #18 Posted March 15, 2015 That has to be it, Eric. Thanks so much for taking the time to help. Share this post Link to post Share on other sites
randym 3 #19 Posted March 15, 2015 Thanks, also, rmaynard. Suspect I'll be spending a fair amount of time around here as my son and I work on getting this tractor back in fighting shape. Share this post Link to post Share on other sites
squonk 44,615 #20 Posted March 15, 2015 I think JD and Cubs have different offset I had a set off a green one that looks like what you have Share this post Link to post Share on other sites
