tbarnhart 240 #1 Posted March 15, 2015 I've always wanted a pressure washer and figured that the attachamatic on the front of the horse would make a great mounting point. I've been collecting parts for a few weeks and finally got a chance to put this together. Here is a shot of the mock-up with the pulley attached to the pump. The pump is 4.0 gpm at 4000 psi and the pulley size puts the engine rpms at 3000. I had an old mule drive that I had used the shaft and pulleys for another project. I added a few pieces of tubing and angle to mount the pump and a fancy "patented" tensioner. I removed the original tensioning screw and added a hook in the rear that locks the whole assembly rigidly to the attachamatic. It works. Now its all disassembled for some paint. It takes about 3 min to install and put on the belt. 18 Share this post Link to post Share on other sites
wmsue 6 #2 Posted March 15, 2015 (edited) Nice job and a great idea! Thanks for posting Bill Edited March 15, 2015 by wmsue Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted March 15, 2015 Awesome build... would like to see some video of it in action. 2 Share this post Link to post Share on other sites
bmsgaffer 2,071 #4 Posted March 15, 2015 That's awesome! I am going to do the same thing as soon as I come across a belt-driven pump at a price I can afford. Its great to have the full pressure washer without having another engine to maintain. Please take some video! Share this post Link to post Share on other sites
312Hydro 474 #5 Posted March 15, 2015 That's original! Well thought out looks good.Now I've got the urge to find a pump like everyone else that sees this. Share this post Link to post Share on other sites
MAH 50 #6 Posted March 15, 2015 Great build. Let's see some pictures when its all painted. Share this post Link to post Share on other sites
bitten 134 #7 Posted March 15, 2015 I wounder if a water tank pulled from the back would give you enough presser to be portable. With a big enough tank you could do the house without messing with a garden hose. 1 Share this post Link to post Share on other sites
oliver2-44 11,572 #8 Posted March 15, 2015 Great idea, a new item on my build list. Share this post Link to post Share on other sites
tbarnhart 240 #9 Posted March 15, 2015 That's awesome! I am going to do the same thing as soon as I come across a belt-driven pump at a price I can afford. Its great to have the full pressure washer without having another engine to maintain. Please take some video! That's original! Well thought out looks good.Now I've got the urge to find a pump like everyone else that sees this. Make sure you do your homework on the many different pumps out there. Rated rpms vary quite a bit and you have to be able to match pulley sizes to get the rpms correct. Then there's the issue of nozzle size and hp requirements. This 4.0gpm@4000 setup puts a good load on the 16hp tecky. 14 would probably run it, 12 would be iffy. I wounder if a water tank pulled from the back would give you enough presser to be portable. With a big enough tank you could do the house without messing with a garden hose. As long as it will gravity feed to the pump, it will work fine. A 100 gallon tank would weigh close to 900 lb. Thats about as heavy as i would want to drag around, but you could wash for 20-25 min at 4 gpm. If I needed to get away from a water supply, I could put something together. Share this post Link to post Share on other sites
can whlvr 994 #10 Posted March 19, 2015 very nice setup,very practical and easy to store ,especially in winter when the washer has to go in the basement so it wont freeze,as far as the water supply it would be far better if you charge the potable with at least 60 lbs air,a washer only amplifies what you give it,gravity fed doesn't work well with any that ive used Share this post Link to post Share on other sites
tbarnhart 240 #11 Posted March 19, 2015 ,as far as the water supply it would be far better if you charge the potable with at least 60 lbs air,a washer only amplifies what you give it,gravity fed doesn't work well with any that ive used I'm sure a pressurized water supply would be better, but General Pump states that this should work on a gravity fed supply as long as it gives sufficient volume. It takes a fairly large line to supply 4 gpm as gravity fed when you don't have a lot of vertical drop. As stated, these pumps don't have any suction to speak of and have to be fed. I got the frame painted and the pump installed. Now I just need to find time to put it to work-The siding on the house needs washed. Share this post Link to post Share on other sites
clip 185 #13 Posted March 21, 2015 Mount a hose reel to the rear and hook it up before you drive to your work location, let it pay out along the way Looks good, love the versatility of the tach-a-matic and pto on these. Share this post Link to post Share on other sites
SethL1984 38 #14 Posted March 26, 2015 Well done sir! I'll hijacking this idea for sure! Share this post Link to post Share on other sites
Rob R 989 #15 Posted March 26, 2015 I have one very similar on my Sears Suburban and it works like a charm...... 1 Share this post Link to post Share on other sites
tbarnhart 240 #16 Posted March 27, 2015 I have one very similar on my Sears Suburban and it works like a charm...... Cool, I'll have to show that to my brother. He has a '66 model Suburban 12 that he is restoring. I noticed that the piston end of your pump was toward the grill. I actually took my pump apart and reversed the crankshaft in order to turn it around. It worked much better with the hose connections toward the front. Just a question, how did you tighten your belt, with the mule drive slide? Share this post Link to post Share on other sites
Rob R 989 #17 Posted March 27, 2015 Yes the pump is driven just like any other Suburban attachment via the mule drive slide lever. Pump has good pressure and works well. Share this post Link to post Share on other sites
bmsgaffer 2,071 #18 Posted April 14, 2015 Could you give a little more information on this? Where did you get the pulley for pump drive? What size was your pump shaft? I'm not sure if i'm just looking in the wrong places (or just stupid ), but I found a nice pump I just need to find a drive pulley that fits 24mm. Which seems to be the most common for high pressure pumps. I will be running on the outside of a standard PTO pulley (which i think is 3.5"), so it looks like I will need about 7" or a little more to bring down to the right speed. Do you have any pictures of the finished product? Or even better a video of it? Thanks! Share this post Link to post Share on other sites
tbarnhart 240 #19 Posted April 14, 2015 To answer a few more of your questions, I used a General HP4040 pump which has a 24mm shaft. It seems most commercial pressure washer pumps do use that size and finished bore pulleys are hard to find. I used a tapered bore pulley that I had here at the shop and ordered a 24mm H-style taper lock hub. Surplus center is your friend for these items. http://www.surpluscenter.com/Power-Transmission/Pulleys/Split-Taper-Bushed-Bore-Pulleys/7-25-O-D-H-BUSHING-SINGLE-GROOVE-PULLEY-1-BKH75.axd http://www.surpluscenter.com/Power-Transmission/Pulleys/Split-Taper-Bushed-Bore-Pulley-Hubs/24mm-METRIC-KEYED-H-BUSHING-1-2915-24.axd My pump was rated 4.0 gpm at 1450 rpms. My pto pulley on my tractor is upsized to speed up my mower deck so I needed a large pulley to get the speed right. The pulley I used sets my engine rpms about 3000. I don't know which pump you are planning to use, but be conscious of the power requirements and belt sizes. It would be hard to get the belt tight enough if I was trying to run my pump on the small pto sheave. The larger sheave helps with that. If your only running a 3.0 gpm @2500psi system, you should be ok. Also, most pumps come with the shaft oriented in such a way that would put the pump pistons toward the hood. I disassembled my pump and turned the crankshaft around to put the hose connections out the front. I don't have any more pics now. If you have any more questions, pm me with your phone number and I'll give you a call. Share this post Link to post Share on other sites
zip628 0 #20 Posted March 4, 2023 And I thought I had an original idea lol me and my son just got our first old wheel horse saved it from a multiflora rose bush death as we are taking apart working on it I discovered how easy these things are to work on and make modifications to and it's amazing wish they still made tractors and mowers like this but yeah I had the same ideas I got old power washer pump works great The motor's junk I was going to take it off and fabricate it to a pulley system to run off the front I got some old alternators laying around eyes going to DIY generator set up with it too the little eight horsepower motor will be fine with the pump I have because it's only being ran by a 5 horsepower motor Right now anyways Share this post Link to post Share on other sites
