Dburnsnavy 0 #1 Posted February 27, 2015 Anybody know where you can buy Rimguard by itself? Tractor dealers carry it but want $75 to pump it in. Thinking about using windshield washer fluid. Thoughts? Share this post Link to post Share on other sites
bmsgaffer 2,069 #2 Posted February 27, 2015 There is a link on the rimguard website that you can contact them to find all your local dealers. Shop around. You cant buy it by itself though. Many DIY'ers use RV antifreeze. Not quite as heavy as rimguard, but its available for the DIYers. (And its safer for your yard, animals and the environment than washer fluid is, but not nearly as cheap) Share this post Link to post Share on other sites
slufoot733 70 #3 Posted February 27, 2015 I have used washer fluid and so far so good. I do have to wonder what it's doing to the rims though. They are well painted but I know constant contact with fluid will eventually get through the paint and eat the metal. I guess I will deal with that when it happens. Share this post Link to post Share on other sites
ri702bill 11,342 #4 Posted February 27, 2015 Yes, winter windshield fluid is a good choice, but it is not as heavy as Rimguard, about 7 and a half lbs./ gallon vs. 11. You would want to use inner tubes with the washer fluid to protect the rims. I did just that on my 854 that has the 8 speed rear from a C-81 in it. I put 4 and a half gallons in each rear and a gallon and a quarter in the fronts. That greatly improved traction both plow and steer. Bill Share this post Link to post Share on other sites
Dburnsnavy 0 #5 Posted February 27, 2015 Even beet juice or powder by itself is very expensive. Since it is considered a health food item Share this post Link to post Share on other sites
snowhound 106 #6 Posted February 27, 2015 I put 6 gal of RV antifreeze in each rear 23X9.5X12 on my C145 loader. It increased stability and traction so well I'm planning on doing the same on my 418-8 with snowblower. Ed Share this post Link to post Share on other sites
