callum12 257 #1 Posted February 24, 2015 hi all, I'm looking into getting some larger front wheels for my A-800, i heard somewhere that the front axles are 3/4"in diameter is this correct? thanks for your help, Callum Share this post Link to post Share on other sites
Kelly 1,036 #2 Posted February 24, 2015 Not 100% sure on your model, but most WH are 3/4" but remember to check length Share this post Link to post Share on other sites
pacer 3,179 #3 Posted February 24, 2015 I dont know for sure either, but is likely 3/4" -- as Kelly says length will vary so be sure and ck that. If replacement hub is shorter a simple spacer behind will allow use of one. Share this post Link to post Share on other sites
callum12 257 #4 Posted February 24, 2015 thank you everyone, i've got a lathe so making spacers won't be a problem. i would have just gone out and checked but my WH isn't close by at the movement! Share this post Link to post Share on other sites
