chazm 413 #2 Posted February 22, 2015 OK.... seen your other post about trans build going bad .... so whats up ? Share this post Link to post Share on other sites
King Horse 22 #3 Posted February 22, 2015 Looks like the case is worn from the bearing being destroyed Share this post Link to post Share on other sites
stevasaurus 23,274 #4 Posted February 22, 2015 Are you looking for some help here?? Nice pictures. I agree...the picture in your other post...that half of the case is toast. Share this post Link to post Share on other sites
King Horse 22 #5 Posted February 22, 2015 I guess its tranny shopping time. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,226 #6 Posted February 22, 2015 Just curious....what Model tractor is this off of?? Share this post Link to post Share on other sites
Terry M-(Moderator) 2,226 #8 Posted February 22, 2015 1045...kinda hard to find tractor. The transmission on this tractor...maybe not as hard to find. This tractor was built with a 5025 model trans per the manuals I've looked up. Other tractors with this model 5025 3 speed unidrive are 854's, 653's, 753's 603's ,633's and probably more. other similar transmissions off other tractors would maybe work too. maybe put an add in the wanted section..you might just find one ... Share this post Link to post Share on other sites
King Horse 22 #9 Posted February 22, 2015 Well that's a nice piece of info. I thought all 3 speeds were universal Share this post Link to post Share on other sites
daveoman1966 3,839 #10 Posted February 22, 2015 If you want just the LEFT SIDE trans case, I have one. I am sending a pm with some pics. my direct email is: daveoman@windstream.net 1 Share this post Link to post Share on other sites
stevasaurus 23,274 #11 Posted February 22, 2015 davoman to the rescue. King Horse, you may want to post some pictures of the shaft that sits in those bearings...thinking get the whole package at once. Share this post Link to post Share on other sites
stevasaurus 23,274 #13 Posted February 23, 2015 Yep...that is called an "11 / 44 toothed" gear or mushroom gear. You would need one from a 5025 3 speed trans...not from a 4 speed transmission. That gear, you have, is long enough to have your brake drum on it. In the 4 speed transmissions, the brake drum sits on the cluster gear shaft (which comes out a different hole) in the trans case. Share this post Link to post Share on other sites
King Horse 22 #14 Posted February 23, 2015 So that gear rides on the #4 needle bearing? Share this post Link to post Share on other sites
stevasaurus 23,274 #15 Posted February 23, 2015 It is hard to tell in your picture, but it looks like a yes. The chewed up end of that gear sits in the spot that is all chewed up. Take a picture that shows the whole inside of that case. Share this post Link to post Share on other sites
King Horse 22 #16 Posted February 23, 2015 I will try but it won't let me upload that big of picture file. I was just confused on why there was a worm gear in a needle bearing. Share this post Link to post Share on other sites
stevasaurus 23,274 #17 Posted February 24, 2015 Right...that is supposed to be smooth. So, did you find any parts?? We have a swap meet coming up April 25th in Mentone, Ind...not far from you. If you can make it, I know a couple of guys that may have all the parts you need. 1 Share this post Link to post Share on other sites
King Horse 22 #18 Posted February 24, 2015 I have some local people with transmissions for sale. Just getting with them is the issue. I am going to try to be there to do some selling. 1 Share this post Link to post Share on other sites
King Horse 22 #19 Posted February 24, 2015 So back to the shaft..so this is the wrong shaft for this transmission? Share this post Link to post Share on other sites
racinfool40 203 #20 Posted February 25, 2015 Spent some time on the phone with King Horse and did some swapping of pics...Think we got it all ironed out... 2 Share this post Link to post Share on other sites
King Horse 22 #21 Posted February 25, 2015 Thanks for all the help. That few minutes was all I needed. Share this post Link to post Share on other sites
bmsgaffer 2,053 #22 Posted February 25, 2015 And that is why this place is awesome. Share this post Link to post Share on other sites
stevasaurus 23,274 #23 Posted February 25, 2015 Thanks Mike...I was just about to get you involved here. See you all at Mentone. 2 Share this post Link to post Share on other sites
wheel-mule 46 #24 Posted February 26, 2015 I will have a couple Trans at Mentone . Share this post Link to post Share on other sites
