AMC RULES 37,260 #26 Posted April 1, 2015 All that, and double the price too. 1 Share this post Link to post Share on other sites
"D"- Man 827 #27 Posted April 4, 2015 Just a quick update on the Carly's have done a cleanup to one that I had mounted, so I took pics. Click on image to enlarge. 2 Share this post Link to post Share on other sites
"D"- Man 827 #28 Posted May 14, 2016 I now have the extra long axles {machined to accommodate dual hubs.} These were made and shipped to me from another Red Square member. The custom axles turned out excellent. 8 Share this post Link to post Share on other sites
Pullstart 71,342 #29 Posted May 15, 2016 Are they in yet are they in yet are they in yet? Huh huh? That is gonna be the sweetest dually conversion to date! Are those stock axles cut/extended and another keyway installed, or are the hot spots at about 9" hardened areas for the bearings by chance? 1 Share this post Link to post Share on other sites
"D"- Man 827 #30 Posted May 15, 2016 Thanks Kevin, No these are not in yet, and no these are not, "stock axles cut/extended and another key-way installed," these were machined from 4140 raw shafts, turned, ground and polished and the gear and bearing areas were hardened via magnetic induction heat-treating. I had an issue with one of the wheels leaking at the welded over valve stem hole and have to get that sorted, then I still need to get the other two tires mounted to the wheels, ect. ect. 1 Share this post Link to post Share on other sites
Pullstart 71,342 #31 Posted May 16, 2016 They looked too pretty to be stock but I was just curious. I wonder if stockers are heat treated or surface hardened near the wearable areas? 1 Share this post Link to post Share on other sites
RedRanger 1,470 #32 Posted May 16, 2016 Nice machining. I get the longer axles, but are there longer housings to support the axles? 1 Share this post Link to post Share on other sites
"D"- Man 827 #33 Posted June 4, 2016 Had a go at doing a mock-up of the transaxle assembled with the extra long axles for duals. I bolted a N.O.S. "T" - Brake disc to the inner hub. I also added a second axle spacer sleeve, between the two hubs. Just for looks a couple items to sort of bling it a bit, the chrome dipstick and the N.O.S. rear hitch. 5 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,590 #34 Posted June 4, 2016 Your certafiable, in a good way. Man of man is that going to be Bad A$$ bling da bling. Looking great. I myself don't have the talent nor the patience. Glenn 2 Share this post Link to post Share on other sites
19richie66 17,937 #35 Posted June 4, 2016 That is NICE! Anticipating the final product 3 Share this post Link to post Share on other sites
