Jakeshorsetuff 36 #1 Posted February 14, 2015 Has anyone else had a problem with the automatic transmission. was plowing driveway the other day went to back out of pile and transmission does not work anymore. Can only get tractor to move about 4 feet forward and 4 feet backwards now. Could no longer get transmission in neutral either had to tow it with a sled to get back in garage as wheels would not spin. Any suggestions before I break it down Thanks Share this post Link to post Share on other sites
rmaynard 16,885 #2 Posted February 14, 2015 Make sure that you don't have a wheel hub that has lost it's woodruff key and is spinning on the axle. Share this post Link to post Share on other sites
Jakeshorsetuff 36 #4 Posted February 14, 2015 no missing keys I have removed the wheels and hubs to test and can only get axles to spin halfway in each direction and then they stop Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted February 14, 2015 It sounds like you dropped a differential bolt. Time for a tear down. Do not try to drive it or you will have bigger problems like a broken case. Share this post Link to post Share on other sites
woodchuckfarmer 333 #6 Posted February 14, 2015 Ive seen that happen. Had to get welded. Share this post Link to post Share on other sites
ericj 1,579 #7 Posted February 14, 2015 i agree you probably lost a differential bolt causing the rear to lock. not a super bad job to pull rear out and take apart and fix, not easy but not impossible either. eric j Share this post Link to post Share on other sites
