cladiesel 1 #1 Posted February 9, 2015 only have low range. would like to pull transaxle but would like a parts breakdown foirst if anyone could steer me in the right direction. thank you Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted February 9, 2015 Not sure the year of your C-165, 1981 to 1984 I think but here is the manual link for the 103916 tranny that is in my C-175. It was used in the C-165 also but maybe not all of them. Share this post Link to post Share on other sites
stevasaurus 23,274 #3 Posted February 9, 2015 Welcome to Red Square. Here is the manual for your trans...it is in section V. 492-4004.pdf (application/pdf Object) We have some videos of putting a trans together if you want the link. We also have a guy that sells parts if you need them...in other words...tell us what we can do to help. Usually what happens to just have either low or high...a shift plate, that moves the gear between low and high is bent or broke. It is an easy fix, but it does require pulling the trans and opening it up. Let us know. Share this post Link to post Share on other sites
