KyBlue 655 #1 Posted February 5, 2015 So I'm putting the last few things on to finish up the rebuild ... the only problem is I don't remember how everything goes .. I'm putting the ignition module on and have two wires. One white one green. Don't recall which goes where. I'd also like to see how the fuel line and the throttle/choke cables are routed. Anybody give me a hand? I'd like to hear this baby run this weekend. Share this post Link to post Share on other sites
19richie66 17,769 #2 Posted February 5, 2015 If the rain stops by this afternoon ill try and get some photos of the linkage. Share this post Link to post Share on other sites
KyBlue 655 #3 Posted February 5, 2015 Thank you very much! Just leaves hooking up the wiring then.... Share this post Link to post Share on other sites
19richie66 17,769 #4 Posted February 6, 2015 Didnt have time to take the air cleaner off but I did get a couple of pictures. The rod that operates the throttle butterfly connects in the second hole on the governor lever. The spring on the other side of the carb is in the second hole on the smaller lever. Ill try to get better pics blue. Sorry i run out of daylight. Share this post Link to post Share on other sites
KyBlue 655 #5 Posted February 6, 2015 Thank you very very much! Share this post Link to post Share on other sites
