ranicotra 0 #1 Posted February 4, 2015 I am desperately searching for a replacement for my bent up idler pulley at the front PTO for my 48" snowblower attachment. It is currently attached to my D-200 Automatic. The Wheelhorse part number looks to be 200153. Can anybody help ? It is about 6" across and keeps throwing the belt under load. Thanks so much for any assistance. Rick Wheel Horse D-200 Auto Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #2 Posted February 4, 2015 200153 looks like the driven pulley on the input shaft of the gearbox. I don't see an idler pulley. If that is the one you need the shaft is likely a standard size so a good cast iron pulley with a tapered hub to fit the shaft should be easily obtained. What is the shaft size? Key size also important - should be 3/16"x3/16"x1" Square Garry Share this post Link to post Share on other sites
