Jack Fate 7 #1 Posted February 2, 2015 (edited) Hi all. Been plow in' snow and i gotta say this thing pushes snow better than it should. Noticed when drive was engaged was hearing a bit to much noise. Pulled side cover and belts got a lot of cracks so I'm going to change it Two questions It would appear I can do this without much more than the main cover off ? & the electric clutch brace removed? Is there a size for this belt anywhere here on this site. I have all original manuals but figure this is just obsolete data .(unless you have a cross reference chart ) I have a industrial supply company for belts but they don't have a good measurement tool Thanks all this is the most we'll behaved site anywhere Edited February 3, 2015 by Jack Fate Share this post Link to post Share on other sites
oldredrider 2,553 #2 Posted February 2, 2015 (edited) The belt number listed in the manual should be correct. I highly recommend Wheel Horse belts for the drive train. They are cut at a particular angle to maximize belt to pulley fit. The belt cover and PTO mount need to be removed to put a new drive belt on, as you suspected. Make sure belt is routed correctly inside the belt guard. Edited February 2, 2015 by oldredrider Share this post Link to post Share on other sites
Jack Fate 7 #3 Posted February 2, 2015 The belt number listed in the manual should be correct. I highly recommend Wheel Horse belts for the drive train. They are cut at a particular angle to maximize belt to pulley fit. The belt cover and PTO mount need to be removed to put a new drive belt on, as you suspected. Make sure belt is routed correctly inside the belt guard. So then I would need to seek out toro dealer ? Was hopeing to just cross reference this to a common belt width & length Thanks for your reply if I can't go local then I'll start calling for toro dealer as the local just shut down Share this post Link to post Share on other sites
meadowfield 2,715 #4 Posted February 3, 2015 I did the same despite advice to use a genuine part. Mine has now done three years of hauling and pulling with no issues! Share this post Link to post Share on other sites
squonk 43,678 #5 Posted February 3, 2015 I've got Napa green belts (Gates) on all of my snow movers. Had them for years no issues. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,433 #6 Posted February 3, 2015 You need a belt designed to withstand the reverse bending over a flat idler pulley. The more common fractional horse power (Fhp) belts are for use on low horse power electric motors but use the same numbering system and will not last. The Wheel Horse/Toro belt is # 8334 - Size B x 84.8" The green Gates # 6985 belt is a suitable replacement - Size 5/8" x 85" The same green Gates belt made for Napa # 5L850W - Size 5/8" x 85" Garry 1 Share this post Link to post Share on other sites
Brrly1 1,146 #8 Posted February 3, 2015 (edited) OEM - 8334, tiller - 9151 I have used both of these belts with No problems!!!! Edited February 3, 2015 by Brrly1 Share this post Link to post Share on other sites
Jack Fate 7 #9 Posted February 3, 2015 You need a belt designed to withstand the reverse bending over a flat idler pulley. The more common fractional horse power (Fhp) belts are for use on low horse power electric motors but use the same numbering system and will not last. The Wheel Horse/Toro belt is # 8334 - Size B x 84.8" The green Gates # 6985 belt is a suitable replacement - Size 5/8" x 85" The same green Gates belt made for Napa # 5L850W - Size 5/8" x 85" Garry Thanks this is what im looking for. And if I had a toro dealer nearby I'd just call them up or stop by on way home from work.This is not the case. For all those who suggested OEM I'm in total agreement .I have done belt replacement in the past by doing this cross reference method with mixed results. I now know why.Thanks to ALL here for the info.Going to check out All my belt options $$$ Cheers Share this post Link to post Share on other sites
Jack Fate 7 #10 Posted February 3, 2015 OEM ordered be about 2 weeks &40clams. Looked online and that was a entire waste of time . Seems there are replacement belts,Toro direct fit belts and Toro "official "belts none of which have any of the numbers I got from you guys[emoji38] Oh and when I looked at all my old WH manuals I found NO belt numbers. I believe the dealer that ordered for me had to do a lot of detective work on cross reference. So I don't really know if I'm getting a OEM , although I expressed this was why I was ordering from them Again thanks all Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,433 #11 Posted February 4, 2015 Every parts list I see shows the 8334 belt 1969-1973. Left over 1972 models were sold with a 1-0502-8 model number. Item # 302 on page 8 of this manual shows the 8334. Drop the 8334 number here you can see it is still good at Toro http://www.rcpw.com/search/?quest=8334 Garry Here the Stens replacement is more $ than the Toro. Share this post Link to post Share on other sites
Jack Fate 7 #12 Posted February 4, 2015 (edited) Thanks book marked second address First one doesn't work , mines a 1973 I didn't see that site, thank you first one doesn't work on tapatalk,PC works but not seeing a belt number I am blind at times tho Edited February 4, 2015 by Jack Fate Share this post Link to post Share on other sites
Big-Game 91 #13 Posted February 5, 2015 If you are still looking for the GT-14 belt 8334 or the tiller belt 9151 send me a message I have close to 400 original wheel Horse belts in stock. Ron rsgreco@embarqmail.com Share this post Link to post Share on other sites
Jack Fate 7 #14 Posted February 5, 2015 If you are still looking for the GT-14 belt 8334 or the tiller belt 9151 send me a message I have close to 400 original wheel Horse belts in stock. Ron rsgreco@embarqmail.com E mail sent Share this post Link to post Share on other sites
Jack Fate 7 #15 Posted February 10, 2015 If you are still looking for the GT-14 belt 8334 or the tiller belt 9151 send me a message I have close to 400 original wheel Horse belts in stock. Ron rsgreco@embarqmail.com I would like to thank this gentleman for promptly supplying me with a OEM /NOS drive belt for a reasonable price Thank you Ron[emoji106] 1 Share this post Link to post Share on other sites
ztnoo 2,300 #16 Posted February 24, 2016 Ditto on Ron for OEM belts. I purchased two belts from Ron Greco (Big_Game) for my GT 14 recently. This is the first time I have tried official WH belts. Got a # 8334 hydro drive belt and a # 9783 PTO deck drive belt. Don't have them installed yet because I'm doing other work on the tractor, but I'm anxious to see how they perform and hold up over time. Ron was super to deal with, a great and prompt communicator, and with very,very reasonable pricing. I would encourage everyone to communicate with Ron about their Wheel Horse belt needs. rsgreco@embarqmail.com Share this post Link to post Share on other sites
