rustykan
C-120 Hood Rattle
rustykan
What is the best way to deal with a rattling hood on a C-120?
daveoman1966
Take out the pivot rod where the hinge is and replace it with a short bolt on each side, 2 washers, and a NYLOK nut to stop the rattle. Draw the NYLOK nuts tight enough that you have to use a little effort to open the hood.
If it is your hood ornament rattling, force a bit of rubber inner tube under it...MAYBE
If the rattle is back near the s/wheel where it locks down to the dash, use a bit of Velcro strip on either side of the latch.
rustykan
I think the rattle is coming from the latch end. I was thinking about some foam adhesive strips, but the velcro would work also and maybe last longer. Don't have a hood ornament, so it's not that.
Shynon
slit some fuel line and put it over the front edge of the dash, then close the hood and latch.
              Tom
