Hodge71 691 #1 Posted January 31, 2015 Does a snowplow mount on a GT-14 like a D series or a C-series? Or is there a specific mount to mount a snow/dozer blade on a GT-14. It has a 3 point on it as well. Not sure if that makes a difference or not... Thanks for the help Share this post Link to post Share on other sites
jeremi3210 743 #2 Posted January 31, 2015 It uses the same rear mount as the d. Share this post Link to post Share on other sites
KC9KAS 4,746 #3 Posted January 31, 2015 The plow on my GT-14 connects to the axle bracket like most others. My problem is the plow frame hits the front axle therefore it doesn't raise very high. Maybe I have the wrong frame. Share this post Link to post Share on other sites
Hodge71 691 #4 Posted January 31, 2015 (edited) Great, now I have 2 guys with 2 different answers....anyone else have a third answer or maybe can clear up the previous 2 statements. Im not exactly sure that 1mounts to the axle like a C and 1 mounts in front of the axle like a D. Unless it a date of manufacture thing... Edited January 31, 2015 by Hodge71 Share this post Link to post Share on other sites
Theroundhousernr 590 #5 Posted January 31, 2015 Mine mounts like a C series from underneath the rear axle. Share this post Link to post Share on other sites
Hodge71 691 #6 Posted January 31, 2015 Mine mounts like a C series from underneath the rear axle. Thats 2 for C series...Almost unanimous...lol Share this post Link to post Share on other sites
KC9KAS 4,746 #7 Posted January 31, 2015 Oh, mine mounts from the bottom up into the bracket...That still doesn't make mine right! Share this post Link to post Share on other sites
Hodge71 691 #8 Posted January 31, 2015 Oh, mine mounts from the bottom up into the bracket...That still doesn't make mine right! No matter which mount you use it mounts from the bottom up into the bracket and the ears pivot down to keep it in. The difference is a C series hangs under the rear axle, a D series mounts in front of the rear axle housing because the D was so much longer than a C. I believe all A-frames are the same. The only difference is the short frame tractors Share this post Link to post Share on other sites
Shynon 7,543 #9 Posted February 1, 2015 Mine mounts to the front side of the axle. Share this post Link to post Share on other sites
Theroundhousernr 590 #10 Posted February 1, 2015 (edited) Had to check mine again after seeing that picture and mine to mounts to the front also. My apology. Edited February 1, 2015 by Theroundhousernr Share this post Link to post Share on other sites
Hodge71 691 #11 Posted February 1, 2015 And with that , the mystery is solved!! Thanks guys... Really appreciate it!! Share this post Link to post Share on other sites
Ken B 3,202 #12 Posted February 1, 2015 Jeff are you fixin to add a GT14 to your herd? I think that will make a nice addition to your fleet. Ya gotta have something heavy to clear that 2 1/2 minute long driveway! 1 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #13 Posted February 1, 2015 I HAVE THE GT-14 THAT JEFF USED TO HAVE. AFTER I GOT IT JEFF REWORKED THE FRAME FOR ME SO NOW THE BLADE LIFTS UP 10 INCHES ABOVE THE GROUND. RUSS Share this post Link to post Share on other sites
Hodge71 691 #14 Posted February 1, 2015 (edited) Jeff are you fixin to add a GT14 to your herd? I think that will make a nice addition to your fleet. Ya gotta have something heavy to clear that 2 1/2 minute long driveway! Well Ken The 18 auto with a 56" blade has always been my snow beast but I have had a soft spot for GT-14s.Unfortunatelt the 18 had been nothing but a hydraulic nightmare since I bought it. I have to go out and tear the pump out today and rip it down to put in a new gasket because the old one leaks like a sieve and a set of new lines because these leak all of a sudden. It marks its spot like an old Harley...lol... Now I have a spare 56" plow and a snowblower for it that I picked up from a local guy for $175. I was thinking that a GT -14 with the spare 56 incher, the 18 with the snowblower or its original 56" blade would make a great team. I would have to get rid of the all original condition 551 that I have to do it but it may be worth it in the long run I HAVE THE GT-14 THAT JEFF USED TO HAVE. AFTER I GOT IT JEFF REWORKED THE FRAME FOR ME SO NOW THE BLADE LIFTS UP 10 INCHES ABOVE THE GROUND. RUSS That must been lots of work Russ. My 18 doesn't get the plow 10 inches in the air and its right against the axle almost Edited February 1, 2015 by Hodge71 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #15 Posted February 1, 2015 JEFF (FIREMAN) WELDED THE FRAME , I CUT A V OUT OF THE FRAME IN FRONT OF THE AXLE TO BEND IT UP. IT WORKS MUCH BETTER NOW. RUSS Share this post Link to post Share on other sites
953 nut 64,268 #16 Posted February 2, 2015 JEFF (FIREMAN) WELDED THE FRAME , I CUT A V OUT OF THE FRAME IN FRONT OF THE AXLE TO BEND IT UP. IT WORKS MUCH BETTER NOW. RUSS Please! Share this post Link to post Share on other sites
