Crown Vic P71 20 #1 Posted January 22, 2015 I know some of you have added duallys to your tractors... My question is how did you do it? Id like to add them to my 312-8 for looks. Thanks! Share this post Link to post Share on other sites
scotty 252 #2 Posted January 22, 2015 Theres a guy on ebay i believe hes a member here and he sells the dual wheel adaptor kits. Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted January 23, 2015 Spacers between the wheels will allow you you join two sets of 'em together. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted January 23, 2015 heres a pic of the adapter I welded,some gas pipe and flat steel 1 Share this post Link to post Share on other sites
857 horse 2,588 #5 Posted January 23, 2015 I SAW THIS WEB SITE,,,,,,,THE ADAPTERS LOOKS ,,,,WELL..... YOU LOOK.... WWW.EXTREMEMOTORWORKS.COM SITE STATES....ANY SIZE... 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #6 Posted January 23, 2015 Is this the place? http://www.xtrememotorworks.com/Parts%20Catalog/Cub%20Cadet%20Parts%20Tires.htm Share this post Link to post Share on other sites
857 horse 2,588 #7 Posted January 24, 2015 yes Craig,, ,,,this site is where i am planning to buy a set....i have 24x12x12 tires,,,,4 of them.. i have 4 wheels 13 inches wide each.... i want an 1 1/2 between them each pair... and my wheel horse 857 tucked in between 2 on each side... i will post the pics,,,,once i learn how to post !!!!!!!!!! darnit Share this post Link to post Share on other sites
bmsgaffer 2,071 #8 Posted January 24, 2015 Be careful that is a WHOLE lot of rubber hanging off each side. The amount of friction when you are turning on a solid surface from the two same side tires working against each other or being on un-level ground is probably enough to worry about axle breaking... Not to mention the serious torture that you will be putting your diff and bearings through. 1 Share this post Link to post Share on other sites
"D"- Man 827 #9 Posted February 21, 2015 (edited) Deleted Edited March 20, 2015 by 23 Automatic LSE Share this post Link to post Share on other sites
