OhioGuy89
Weird Starting Noise
ericj
Maybe. Although I know they don't buy used equipment outright there. I mean, I did turn the flywheel the wrong way once to make sure things turned. Could that have broken something?
if that was the case i would have a whole bunch of broken motors and tractors
eric j
OhioGuy89
Ah. I still say it's the starter. On the phone, he made it seem like they really didn't want to bother working on it
Stigian
I can't see you would of broken both con rods by doing that!!      If a con rod was broken you would of heard it hitting things inside the engine case..
Have you tried jump starting? The extra power may what's needed....
JackC
I bought a low hour 417A with a Kohler KT17 Series II for $250. The deck alone was worth $250.  The PO said there was no spark and the shop he took it to told him the stater was bad. After I found and fixed a bad connection to the condenser it started right up.
If your engine ran before monkeying with it then the engine internals are probably fine.  The symptoms you describe are typical for when there is a weak battery or bad connection or both.
steve k
Your con rods are not broken......    what is the voltage across the battery terminals while key is off?    12.7= full battery   12.5 still ok    12.0 or lower= not enough   either charge battery or jump it from another.    It probably is the starter however,   pull it off and inspect it, clean and either test yourself with jumper cables or take it to an auto parts store to have it tested.  In post thirteen you said voltage drop across battery terminals was .5 volts while cranking.
First, if the voltage is .5 while attempting to crank that is BAD.   battery is shot.     Reread Save Old Irons post again and look at the diagrams, everything he posted is spot on.
Steve
Edited by steve k
