chev0545
520 flywheel
chev0545
does the ring gear come off the flywheel,or do you have to replace the whole flywheel?either way does anybody have one for a p220g model?
thanks for any help
Dirtdog524
I know i have one for the 16hp engine but i am not sure if they are the same.
  :eusa-think:
ericj
the starter ring does come off and the 16, 18 and p220 flywheels do interchange. i just had the ring replaced on one of my flywheels because of the po not tightening the flywheel down tight and miss-matching the starter and flywheel. luckily i had a flywheel that had broken and lost magnets on it so a friend swapped the rings for me  but i didn't see how he did it. i know he used a brass drift punch and heat to remove and re install the ring. good luck
eric j
