jwiss1995
414-8 trans fluid
jwiss1995
im wanting to change the fluid in my 414-8 but im wondering what fluid to use and how much. also, where is the drain plug on these? also, it seems like there is some water in the trans. should i worry about flushing it or just drain it and fill it with new fluid? it works fine, just wanna get good fluid in it. thanks in advance!
varosd
The answer is always just a few clicks away.. :D
there is multiple posts about flushing a tranny.
drain plug under the tranny, it is a recessed hex
scotty
Alot of the trannys i change the gear oil in always has some water. If the boot was destroyed and left outside and if the oil looks bad then i flush it. I use 80w-90 gear oil in mine.
jwiss1995
looks like im gonna get some fluid tomorrow at work and have another reason to work on the horse tomorrow night!! :woohoo:
