wesley 32 #1 Posted January 10, 2015 hi every one its been ages since l was in here,my poor old raider went an through the con rod and piston also the crank ,did have a look at new prices for parts and was shocked the crank worked at at the time £160 uk pounds so pushed it in the back of the shop an did not bother , but getting fire wood moved has been a pain since then , so looked around again and have found a k241t engine thats missing the carb etc ,but the rest of it is ok ,so now l have found a ray of light ,the old lady will be got out and with luck running again soon ,am hoping to build one engine from the both ie flywheel etc so that l can still use the electric start etc , and yes lts good in away to be back in the forum with a horse again, weeeeeeee hope regards wes Share this post Link to post Share on other sites
neil 2,415 #2 Posted January 10, 2015 Welcome back wes , wish you luck with the transplant , not having a tractor to hand is like losing a leg Share this post Link to post Share on other sites
wesley 32 #3 Posted January 11, 2015 Welcome back wes , wish you luck with the transplant , not having a tractor to hand is like losing a leg many thanks yes to be honest hate seing the tractor just sitting,what firm do you use for parts , think l will give my carb a new float bowl gasket etc . wes Share this post Link to post Share on other sites
Stigian 1,235 #4 Posted January 11, 2015 It's good to have you back Wes, it's a shame your poor Raider decided to eat it's engine internals, but I'm sure your have it fixed in no time. Share this post Link to post Share on other sites
JC 1965 1,548 #5 Posted January 11, 2015 Welcome back Wes. Share this post Link to post Share on other sites
