wrmhaste 235 #1 Posted January 8, 2015 So I'm working on the 73' 10hp automatic. It smokes a little until it gets warmed up and I'm thinking a good cleaning and inspection is in order. I looked in the manual section for an engine manual. I found a couple for the k241 but I wasn't sure if they were the same. I'm looking for valve adjustment specs and now also looking for the difference between the k241 and the K241s. Is it just starter generator? Share this post Link to post Share on other sites
rmaynard 16,837 #2 Posted January 8, 2015 K241S means starter, whether starter generator or otherwise. The A designation means special oil pan, and a T usually means pull-start. The proper manual for you to download is: Share this post Link to post Share on other sites
wrmhaste 235 #3 Posted January 8, 2015 Wow thanks! That was fast Share this post Link to post Share on other sites
