JustinW.73 224 #26 Posted January 8, 2015 U sure the battery in the volt meter is good. I've gotten false readings from a bad meter battery. Share this post Link to post Share on other sites
Coley909 12 #27 Posted January 8, 2015 Pretty positive Share this post Link to post Share on other sites
JustinW.73 224 #28 Posted January 8, 2015 I'd double check. Very easy thing to do. 99% of the time it isn't but theres always that chance. Share this post Link to post Share on other sites
Coley909 12 #29 Posted January 8, 2015 Ill check it when I do my adjustment on the regulator Share this post Link to post Share on other sites
KyBlue 655 #30 Posted January 8, 2015 Don't have much to add but good luck! I know you'll get it figured out. 1 Share this post Link to post Share on other sites
Coley909 12 #31 Posted January 8, 2015 I sure hope for something so simple it's getting really frustrating Share this post Link to post Share on other sites
RubyCon1 63 #32 Posted January 8, 2015 U sure the battery in the volt meter is good. I've gotten false readings from a bad meter battery. the 99 cent harbor freight meters are notorious for this 1 Share this post Link to post Share on other sites
Save Old Iron 1,573 #33 Posted January 8, 2015 (edited) U sure the battery in the volt meter is good. I've gotten false readings from a bad meter battery. Bad (high) readings are possible with aging meter batteries but the believable 12.6 volts measured at the battery suggests the meter battery is OK. Most digital meters have some sort of low battery warning on the display. You can measure the battery in your car to check if the meter is correct. Edited January 8, 2015 by Save Old Iron 1 Share this post Link to post Share on other sites
Save Old Iron 1,573 #34 Posted January 8, 2015 I'll ask this a third time and I'll keep it short and sweet so as not to distract. If you remove the F field wire from the SG, does the 20 volts drop to near zero volts ? It's OK to reply "I don't know which wire is the field wire". 1 Share this post Link to post Share on other sites
Coley909 12 #35 Posted January 8, 2015 I will check it along with what geno asked me. I've been working and haven't had a chance in the day light to go out and check yet. Share this post Link to post Share on other sites
Coley909 12 #36 Posted January 8, 2015 Sg drops to near zero when field is removed. 22 steady otherwise. Battery is slowly charging at battery and voltage at battery terminal on regulator are between 13.5 and 14 half throttle not much difference at full still within that spectrum. Battery is sitting around 11.8 to 12.2 currently at half throttle 1 Share this post Link to post Share on other sites
Coley909 12 #37 Posted January 8, 2015 This is how it's wired currently. I didn't adjust anything because it looks nothing like the diagram from the forum on how to adjust it. Share this post Link to post Share on other sites
Geno 1,930 #38 Posted January 8, 2015 Check the ground on the regulator body, you can run a wire from the mount to the neg of the battery if you like. If there is voltage to the Bat terminal from the battery and a good ground to the regulator body then that's enough considering someone got paid to fix the rest. If nothing changes call the person who's already been paid to make it charge and let them fix it. 1 Share this post Link to post Share on other sites
Molon_Labe 731 #39 Posted January 8, 2015 Good point Geno because some of the older regulators had an isolated (above ground) mount. 1 Share this post Link to post Share on other sites
Coley909 12 #40 Posted January 8, 2015 it doesn't have a good ground, Didn't help much but it did help. Picked up to around 12.5 at the battery this time i could take the negative on and off watching voltage drop down to 11.6 to 12.5ish so I will add that when i get it back but i think I should take the tractor back. I swear it sounds like the regulator is squeeling. 1 Share this post Link to post Share on other sites
Geno 1,930 #41 Posted January 8, 2015 Sounds like it's all worked out then. Let the rebuilder fix what he is supposed to fix then make sure you have a good ground path when you get it back and you'll be good to go. Share this post Link to post Share on other sites
Coley909 12 #42 Posted January 8, 2015 Will do ill call him tomorrow and keep you guys updated. 1 Share this post Link to post Share on other sites
Coley909 12 #43 Posted January 14, 2015 Update tractor was finished today free of charge even though at first they blamed me. Turns out the voltage reg went to full field what ever that means so they replaced and boom 14 volts charging 1 Share this post Link to post Share on other sites
Geno 1,930 #44 Posted January 14, 2015 I don't know why business have to blame the customer first. I haven't done that in my business and it comes back to you tenfold. It's nice that you got it all sorted out and didn't have to pay any more! Share this post Link to post Share on other sites
Coley909 12 #45 Posted January 14, 2015 Thanks geno I'm happy it's back and working even though it is to cold to snow at the moment to get to use it 1 Share this post Link to post Share on other sites
Geno 1,930 #46 Posted January 14, 2015 There's plenty of Winter left... Share this post Link to post Share on other sites
Save Old Iron 1,573 #48 Posted January 15, 2015 Sg drops to near zero when field is removed. 22 steady otherwise. Battery is slowly charging at battery and voltage at battery terminal on regulator are between 13.5 and 14 half throttle not much difference at full still within that spectrum. Battery is sitting around 11.8 to 12.2 currently at half throttle That is how the reg works. Full field or partially on and switching rapidly between those two voltages - thus "averaging out" to 14.something. This is also why the relay contacts BUZZZZZZZZZZZ. If you can correct the over voltage by removing the field wire, the issue is the reg or the reg wiring. Glad it worked out for you. 1 Share this post Link to post Share on other sites
Save Old Iron 1,573 #49 Posted January 15, 2015 (edited) Full field on a dc generator is when the field coils inside the generator are connected directly to ground and not thru any external resistors (those wire wound elements on the bottom of the reg). Full fielding causes maximum voltage output from the generator. Edited January 15, 2015 by Save Old Iron 1 Share this post Link to post Share on other sites
