jim3sr 2 #1 Posted January 3, 2015 My plow blade ID # is mod 6 9622 7 according to various manuals for my 1987 310-8 should be 06-36mr04.What exactly do I have and how should it be entered in a parts search? Also the piece that runs from release lever to index plate,this is a rod?I don't have it,can I buy it? ( I have downloadedPDF#810280.1 ) If I can't buy it what can I substitute for this? The area that the release lever passes by the brake pedal doesn't seem to have enough room.Plow frame is Mod# is 41137 is this correct? Can this be slid over 1/4-1/2" to allow better clearance for release lever? Share this post Link to post Share on other sites
Lane Ranger 11,410 #2 Posted January 3, 2015 (edited) On your blade (and other Wheel Horse tractors and attachments) you can go to Partstree.com and do a search on parts, find drawings , etc. www.partstree.com/ Looks like your snowplow (Model 6 9622) is a 1970 snowplow for a long frame Wheel Horse tractor. Plow should fit on your tractor but the pivot handle/lever on right side will not have the offset that later model plows had to clear the footrest on your 310-8 tractor. Also the 06-36mr04 sounds like a 36 inch rear discharge mower deck number -not a plow number for your 310-8 tractor. The rod can be fabbed from some steel bought at a Tractor Supply Store or other rural/ag supply -even Lowes or Home Depot. Edited January 3, 2015 by Lane Ranger Share this post Link to post Share on other sites
doc724 925 #3 Posted January 3, 2015 Jim, I was confused by your original post, but Lane Ranger cleared it up for me. In addition to making the parts you need, you may also find a used one from Kelly (see RS vendors section). Someone on RS in the last 4-6 weeks made one of the pivot levers. Do a search in the implements section. Partstree has everything you need, but parts are expensive. I have found that Jacks Small Engine has the best pricing for most WH parts that I have to buy new Share this post Link to post Share on other sites
KyBlue 655 #4 Posted January 3, 2015 (edited) I made a new lever cause I'm too cheap to buy the new one from toro... Ten dollars in steel and a dollar or two in map gas & oxygen and viola! I'm still doing the release handle - you can use anything for that rod... Bailing wire...or mechanics wire... Something along those lines. Edited January 3, 2015 by KyBlue Share this post Link to post Share on other sites
jim3sr 2 #5 Posted January 3, 2015 Sorry I think I pulled that 310-8 plow # out of nowhere should be 06-48BC01 Thanks for ur help will check kelly's Share this post Link to post Share on other sites
KyBlue 655 #6 Posted January 3, 2015 (edited) Looks like you'll need this angle lever ... Toro 94668601 LEVER INDEX Price: $34.92 Toro 104341 UPPER INDEX ROD Price: $8.62 and the upper piece you squeeze is NLA ... but was: Toro 5107 DISCONTINUED Price: No Longer Available Edit: PartsTree.com lists the Part 5107 as Discontinued but can still be added to your cart. You might call them to see if they have a few on the shelf. List Price $46.40 Edited January 3, 2015 by KyBlue Share this post Link to post Share on other sites
KC9KAS 4,744 #7 Posted January 3, 2015 I have used a coat hanger (straightened) to make the "rod" before. I also have used a small diameter cable with cable clamps instrad of the rod. It is not necessairly being "cheap" just "frugal"! 3 Share this post Link to post Share on other sites
jim3sr 2 #8 Posted January 3, 2015 can't I just use the strait lever I have and just have it bent Share this post Link to post Share on other sites
KC9KAS 4,744 #9 Posted January 3, 2015 can't I just use the strait lever I have and just have it bent Sure, if it will still be long enough after you bend a couple of 90* bends in it. I have used 1/4" flat steel 1 1/4" wide and made my own lift lever. 1 Share this post Link to post Share on other sites
KyBlue 655 #10 Posted January 4, 2015 Sure, if it will still be long enough after you bend a couple of 90* bends in it. I have used 1/4" flat steel 1 1/4" wide and made my own lift lever. I think mine was a bit thicker but it's 1 1/4 wide...Simple to fab Share this post Link to post Share on other sites
KC9KAS 4,744 #11 Posted January 4, 2015 I think mine was a bit thicker but it's 1 1/4 wide...Simple to fab Yeah, the 1/4" one was a little flimsey....3/8" would have been better....Live & learn!! 1 Share this post Link to post Share on other sites
KyBlue 655 #12 Posted January 4, 2015 IIRC - the first one I did was 1/4 and found out the same thing that you did ... as you said, live and learn Share this post Link to post Share on other sites
