Retired Wrencher 6,382 #1 Posted December 29, 2014 (edited) 3 weeks ago I started to clean the b-80 every thing work lights started right up. But it was very dirty from mowing since 1996 when 2nd owner bought it. so now it is all cleaned up put in the battery in NOTHING Dead so I check all wires for continuity every thing looks good there. I have a new switch, check that against the old switch. It was the same. Cleaned all switches with contact cleaner spray. So I am thinking solenoid or starter??? I did bang on starter to see if it did work nothing. I did hot wirer from starter to ground that worked it turned over. ANY IDEAS?????? Gary B.... Edited December 29, 2014 by T1257 Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted December 29, 2014 (edited) Examples that show test, repair, and or replace... https://www.youtube.com/results?search_query=starter+solenoid+rebuild+ Edited December 29, 2014 by AMC RULES 1 Share this post Link to post Share on other sites
Retired Wrencher 6,382 #3 Posted December 29, 2014 Examples that show test, repair, and or replace... o https://www.youtube.com/results?search_query=starter+solenoid+rebuild+ Thanks Craig I just went out and tested it. the 2 poles have power but nothing coming from the clutch safe switch pole. So with that I am thinking it is the safety switch. I will go to nappa tomorrow and see if I can get one. Gary Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted December 29, 2014 Hammers don't "fix" electrical problems. Get the wiring diagram and go from there. Your new switch may look the same but double check the posts with an ohm meter. Share this post Link to post Share on other sites
squonk 45,391 #5 Posted December 29, 2014 If you have an ammeter check that. I have seen this dozens of times and the connection at the meter is either loose or dirty 1 Share this post Link to post Share on other sites
Retired Wrencher 6,382 #6 Posted December 29, 2014 If you have an ammeter check that. I have seen this dozens of times and the connection at the meter is either loose or dirty Hammers don't "fix" electrical problems. Get the wiring diagram and go from there. Your new switch may look the same but double check the posts with an ohm meter. Ok Guys I will check that in the AM for Continuity. I found a new switch on E-Bay for $18.00 so I will keep u posted. Gary B..... Share this post Link to post Share on other sites
