formariz 12,081 #1 Posted December 26, 2014 Time to separate twins sucessfull operation they can now see each other 1 Share this post Link to post Share on other sites
Dhodge 528 #2 Posted December 26, 2014 Those are very nice. I want one of those air cleaners. If you run across any let me know as I am missing one from my Clinton Share this post Link to post Share on other sites
AMC RULES 37,226 #3 Posted December 26, 2014 (edited) I believe, to be correct... that type of up draft air cleaner should have it's louvered openings facing down. Edited December 26, 2014 by AMC RULES Share this post Link to post Share on other sites
formariz 12,081 #4 Posted December 26, 2014 I believe, to be correct... that type of up draft air cleaner should have it's louvered openings facing down. That is correct. One can turn the carburater fitting so it is in a downdraft position and this would be the air cleaner for that since the orientation of louver would then be correct. However I suspect that the real function of the louver orientation is only to protect filter from water entering it if exposed to the elements. Since the hood is over it in this case I dont believe it to be an issue. Also while in my posession this thing is never going to see a drop of water Share this post Link to post Share on other sites
