drscooby 0 #1 Posted December 26, 2014 FOUND A K91 FOR MY 1960 WH WITH OIL BATH IT IS ON A TILLER WITH A WHAT LOOKS LIKE A GEAR REDUCTION AND A DOUBLE PULLEY ON IT WILL IT FIT MY HORSE. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #2 Posted December 26, 2014 Not with gear reduction. Share this post Link to post Share on other sites
VinsRJ 724 #3 Posted December 26, 2014 You can use it but you will have to swap out the crankshaft with an appropriate 3/4" keyed PTO shaft. Share this post Link to post Share on other sites
drscooby 0 #4 Posted December 26, 2014 Does the gear reduction come off and I have just a 3/4 shaft Share this post Link to post Share on other sites
Racinbob 13,286 #5 Posted December 26, 2014 I believe you have a pinion gear on the end of the crankshaft. It's not going to work for you without changing the crankshaft. Share this post Link to post Share on other sites
